[petsc-users] Double-colon target
Tuan Nguyen tuan.vawr at gmail.com
Tue Jun 2 14:38:36 CDT 2015
Thanks Matt!
It works now but there is issue of memory occur:
PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably
memory access out of range
[3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[3]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[3]PETSCERROR:
or try http://valgrind.org on linux or man libgmalloc on Apple to find
memory corruption errors
[3]PETSC ERROR: likely location of problem given in stack below
[3]PETSC ERROR: ---------------------  Stack Frames
[3]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[3]PETSC ERROR:       INSTEAD the line number of the start of the function
[3]PETSC ERROR:       is given.
[3]PETSC ERROR: --------------------- Error Message
[3]PETSC ERROR: Signal received!
​I am planning to find where in the code the error occur by using valgrind.
Could you please let me know how to do this?
Here is the command I use to run the code:
/opt/openmpi/mpirun -np 10 ./fvom --casename=lake>info.dat
​Thanks,​
On Tue, Jun 2, 2015 at 1:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jun 2, 2015 at 12:17 PM, Tuan Nguyen <tuan.vawr at gmail.com> wrote:
>> Dear all,
>> I installed PETSC 3.1-p8 library. I am trying compile the fortran code
>> link to Petsc but there is message saying about target file as follow:
>> *petsc-3.1-p8-openmpi/conf/rules:120: *** target file `clean' has both :
>> and :: entries.  Stop.*
>> ​In my "makefile" I added double-colon to target clean but it will bring
>> me to another error message:
>> */home/petsc-3.1-p8-openmpi/conf/rules:299: warning: overriding commands
>> for target `.c.o'makefile:39: warning: ignoring old commands for target
>> `.c.o'/home/petsc-3.1-p8-openmpi/linux-gnu-c-debug/conf/petscrules:31:
>> warning: overriding commands for target `.F.o'makefile:42: warning:
>> `.F.o'/home/petsc-3.1-p8-openmpi/linux-gnu-c-debug/conf/petscrules:31:
>> warning: overriding commands for target `.F90.o'makefile:47: warning:
>> ignoring old commands for target `.F90.o'*
>> /bin/rm -f *.o *.mod *.f90
>> ​Could any one help me?
> In your makefile, you have rules for .c.o, etc. You either use the PETSc
> makefiles, which define these rules, or
> use your own rules, in which case just use the conf/variables file which
> defines our make vars.
>    Matt
>> Thanks,​
>> Tuan
> experiments lead.
> -- Norbert Wiener
Tuan Nguyen
Michigan State University
East Lansing, MI. 48823
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150602/c108e0db/attachment.html>
