[petsc-users] Double-colon target
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Jun  2 14:43:02 CDT 2015
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> On Jun 2, 2015, at 2:38 PM, Tuan Nguyen <tuan.vawr at gmail.com> wrote:
> Thanks Matt!
> It works now but there is issue of memory occur:
> PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[3]PETSCERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to find memory corruption errors
> [3]PETSC ERROR: likely location of problem given in stack below
> [3]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [3]PETSC ERROR:       INSTEAD the line number of the start of the function
> [3]PETSC ERROR:       is given.
> [3]PETSC ERROR: --------------------- Error Message ------------------------------------
> [3]PETSC ERROR: Signal received!
> I am planning to find where in the code the error occur by using valgrind. Could you please let me know how to do this?
> Here is the command I use to run the code:
> /opt/openmpi/mpirun -np 10 ./fvom --casename=lake>info.dat
> Thanks,
> On Tue, Jun 2, 2015 at 1:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jun 2, 2015 at 12:17 PM, Tuan Nguyen <tuan.vawr at gmail.com> wrote:
> Dear all,
> I installed PETSC 3.1-p8 library. I am trying compile the fortran code link to Petsc but there is message saying about target file as follow:
> petsc-3.1-p8-openmpi/conf/rules:120: *** target file `clean' has both : and :: entries.  Stop.
> In my "makefile" I added double-colon to target clean but it will bring me to another error message:
> /home/petsc-3.1-p8-openmpi/conf/rules:299: warning: overriding commands for target `.c.o'
> makefile:39: warning: ignoring old commands for target `.c.o'
> /home/petsc-3.1-p8-openmpi/linux-gnu-c-debug/conf/petscrules:31: warning: overriding commands for target `.F.o'
> makefile:42: warning: ignoring old commands for target `.F.o'
> /home/petsc-3.1-p8-openmpi/linux-gnu-c-debug/conf/petscrules:31: warning: overriding commands for target `.F90.o'
> makefile:47: warning: ignoring old commands for target `.F90.o'
> /bin/rm -f *.o *.mod *.f90
> Could any one help me?
> In your makefile, you have rules for .c.o, etc. You either use the PETSc makefiles, which define these rules, or
> use your own rules, in which case just use the conf/variables file which defines our make vars.
>    Matt
> Thanks,
> Tuan
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> Tuan Nguyen
> Michigan State University
> East Lansing, MI. 48823
