[petsc-users] Symmetric MPIAIJ matrix
Tue Jul 7 15:54:08 CDT 2015
On Tue, Jul 7, 2015 at 3:52 PM, Bikash Kanungo <bikash at umich.edu> wrote:
> Hi Matthew,
> I couldn't follow your reply. It seems a bit unrelated to my query.
Your matrix actually looks like M = A + v^T v, where A is sparse and v is a
small collection of vectors. It is better
is you handle it this way than putting a dense row into a traditional
sparse matrix.
   Matt
> Thanks,
> Bikash
> On Tue, Jul 7, 2015 at 4:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Jul 7, 2015 at 3:36 PM, Bikash Kanungo <bikash at umich.edu> wrote:
>>> Hi Matthew,
>>> The entries to the last few rows of my matrix has non-local
>>> contributions from a large number of processors. Since the matrix is
>>> symmetric, I need not set the non-local entries in the last few rows as
>>> they are equal to their transpose entries, which on the other hand are
>>> stored as local entries in their respective processors.
>> This is really a sparse matrix with a low rank update. It is much easier
>> to handle it this way. There are explicit formulae for the inverse
>> in terms of the inverse of the two parts (Sherman-Morrison-Woodbury), and
>> other operations can be similarly simplified. We might not
>> have all the support now, but pressing forward on this front is likely to
>> be much more fruitful.
>>   Thanks,
>>     Matt
>>> Thanks,
>>> Bikash
>>> On Tue, Jul 7, 2015 at 4:25 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Tue, Jul 7, 2015 at 3:22 PM, Bikash Kanungo <bikash at umich.edu>
>>>> wrote:
>>>>> Hi,
>>>>> Is there a way to ignore the lower (or upper) triangular entries in an
>>>>> MATMPIAIJ matrix when I know my matrix is symmetric? I can see a
>>>>> MAT_SYMMETRIC option in MatSetOption, but I don't think it ignores any
>>>>> lower (or upper) triangular entry.
>>>> Why do you want this?
>>>>> I cannot use MATMPISBAIJ due to MatMatMult incompatibility with
>>>>> MATMPIAIJ.
>>>> This is the only way. MatMatMult() is quite complex and there is no
>>>> real advantage to ignoring
>>>> the entries, so we have not implemented it here.
>>>>   Matt
>>>>> Thanks,
>>>>> Bikash
>>>>> Bikash S. Kanungo
>>>>> PhD Student
>>>>> Computational Materials Physics Group
>>>>> Mechanical Engineering
>>>>> University of Michigan
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Bikash S. Kanungo
>>> PhD Student
>> experiments lead.
>> -- Norbert Wiener
> Bikash S. Kanungo
> PhD Student
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150707/1a33d0f1/attachment.html>
