[petsc-users] Symmetric MPIAIJ matrix
Bikash Kanungo bikash at umich.edu
Tue Jul 7 16:00:58 CDT 2015
Aha ! That should do the trick. Thanks a lot.
On Tue, Jul 7, 2015 at 4:54 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jul 7, 2015 at 3:52 PM, Bikash Kanungo <bikash at umich.edu> wrote:
>> Hi Matthew,
>> I couldn't follow your reply. It seems a bit unrelated to my query.
> Your matrix actually looks like M = A + v^T v, where A is sparse and v is
> a small collection of vectors. It is better
> is you handle it this way than putting a dense row into a traditional
> sparse matrix.
>    Matt
>> Thanks,
>> Bikash
>> On Tue, Jul 7, 2015 at 4:42 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Jul 7, 2015 at 3:36 PM, Bikash Kanungo <bikash at umich.edu> wrote:
>>>> Hi Matthew,
>>>> The entries to the last few rows of my matrix has non-local
>>>> contributions from a large number of processors. Since the matrix is
>>>> symmetric, I need not set the non-local entries in the last few rows as
>>>> they are equal to their transpose entries, which on the other hand are
>>>> stored as local entries in their respective processors.
>>> This is really a sparse matrix with a low rank update. It is much easier
>>> to handle it this way. There are explicit formulae for the inverse
>>> in terms of the inverse of the two parts (Sherman-Morrison-Woodbury),
>>> and other operations can be similarly simplified. We might not
>>> have all the support now, but pressing forward on this front is likely
>>> to be much more fruitful.
>>>   Thanks,
>>>     Matt
>>>> Thanks,
>>>> Bikash
>>>> On Tue, Jul 7, 2015 at 4:25 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Tue, Jul 7, 2015 at 3:22 PM, Bikash Kanungo <bikash at umich.edu>
>>>>> wrote:
>>>>>> Hi,
>>>>>> Is there a way to ignore the lower (or upper) triangular entries in
>>>>>> an MATMPIAIJ matrix when I know my matrix is symmetric? I can see a
>>>>>> MAT_SYMMETRIC option in MatSetOption, but I don't think it ignores any
>>>>>> lower (or upper) triangular entry.
>>>>> Why do you want this?
>>>>>> I cannot use MATMPISBAIJ due to MatMatMult incompatibility with
>>>>>> MATMPIAIJ.
>>>>> This is the only way. MatMatMult() is quite complex and there is no
>>>>> real advantage to ignoring
>>>>> the entries, so we have not implemented it here.
>>>>>   Matt
>>>>>> Thanks,
>>>>>> Bikash
>>>>>> Bikash S. Kanungo
>>>>>> PhD Student
>>>>>> Computational Materials Physics Group
>>>>>> Mechanical Engineering
>>>>>> University of Michigan
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Bikash S. Kanungo
>>>> PhD Student
>>> experiments lead.
>>> -- Norbert Wiener
>> Bikash S. Kanungo
>> PhD Student
> experiments lead.
> -- Norbert Wiener
Bikash S. Kanungo
PhD Student
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150707/bb43091b/attachment-0001.html>
