[petsc-users] Symmetric MPIAIJ matrix
Bikash Kanungo
bikash at umich.edu
Tue Jul 7 15:52:17 CDT 2015
Hi Matthew,
I couldn't follow your reply. It seems a bit unrelated to my query.
Bikash
On Tue, Jul 7, 2015 at 4:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jul 7, 2015 at 3:36 PM, Bikash Kanungo <bikash at umich.edu> wrote:
>> Hi Matthew,
>> The entries to the last few rows of my matrix has non-local contributions
>> from a large number of processors. Since the matrix is symmetric, I need
>> not set the non-local entries in the last few rows as they are equal to
>> their transpose entries, which on the other hand are stored as local
>> entries in their respective processors.
> This is really a sparse matrix with a low rank update. It is much easier
> to handle it this way. There are explicit formulae for the inverse
> in terms of the inverse of the two parts (Sherman-Morrison-Woodbury), and
> other operations can be similarly simplified. We might not
> have all the support now, but pressing forward on this front is likely to
> be much more fruitful.
> Thanks,
> Matt
>> Thanks,
>> Bikash
>> On Tue, Jul 7, 2015 at 4:25 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Jul 7, 2015 at 3:22 PM, Bikash Kanungo <bikash at umich.edu> wrote:
>>>> Hi,
>>>> Is there a way to ignore the lower (or upper) triangular entries in an
>>>> MATMPIAIJ matrix when I know my matrix is symmetric? I can see a
>>>> MAT_SYMMETRIC option in MatSetOption, but I don't think it ignores any
>>>> lower (or upper) triangular entry.
>>> Why do you want this?
>>>> I cannot use MATMPISBAIJ due to MatMatMult incompatibility with
>>>> MATMPIAIJ.
>>> This is the only way. MatMatMult() is quite complex and there is no real
>>> advantage to ignoring
>>> the entries, so we have not implemented it here.
>>> Matt
>>>> Thanks,
>>>> Bikash
>>>> Bikash S. Kanungo
>>>> PhD Student
>>>> Computational Materials Physics Group
>>>> Mechanical Engineering
>>>> University of Michigan
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> Bikash S. Kanungo
>> PhD Student
> experiments lead.
> -- Norbert Wiener
Bikash S. Kanungo
PhD Student
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150707/b98737a8/attachment.html>
