[petsc-users] Symmetric MPIAIJ matrix
Matthew Knepley
knepley at gmail.com
Tue Jul 7 15:42:54 CDT 2015
On Tue, Jul 7, 2015 at 3:36 PM, Bikash Kanungo <bikash at umich.edu> wrote:
> Hi Matthew,
> The entries to the last few rows of my matrix has non-local contributions
> from a large number of processors. Since the matrix is symmetric, I need
> not set the non-local entries in the last few rows as they are equal to
> their transpose entries, which on the other hand are stored as local
> entries in their respective processors.
This is really a sparse matrix with a low rank update. It is much easier to
handle it this way. There are explicit formulae for the inverse
in terms of the inverse of the two parts (Sherman-Morrison-Woodbury), and
other operations can be similarly simplified. We might not
have all the support now, but pressing forward on this front is likely to
be much more fruitful.
Matt
> Thanks,
> Bikash
> On Tue, Jul 7, 2015 at 4:25 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Jul 7, 2015 at 3:22 PM, Bikash Kanungo <bikash at umich.edu> wrote:
>>> Hi,
>>> Is there a way to ignore the lower (or upper) triangular entries in an
>>> MATMPIAIJ matrix when I know my matrix is symmetric? I can see a
>>> MAT_SYMMETRIC option in MatSetOption, but I don't think it ignores any
>>> lower (or upper) triangular entry.
>> Why do you want this?
>>> I cannot use MATMPISBAIJ due to MatMatMult incompatibility with
>>> MATMPIAIJ.
>> This is the only way. MatMatMult() is quite complex and there is no real
>> advantage to ignoring
>> the entries, so we have not implemented it here.
>> Matt
>>> Thanks,
>>> Bikash
>>> Bikash S. Kanungo
>>> PhD Student
>>> Computational Materials Physics Group
>>> Mechanical Engineering
>>> University of Michigan
>> experiments lead.
>> -- Norbert Wiener
> Bikash S. Kanungo
> PhD Student
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150707/93458ffb/attachment-0001.html>
