[petsc-users] Conversion between AIJ & BAIJ
Chung-Kan Huang ckhuangf at gmail.com
Wed Jan 21 16:21:34 CST 2015
On Wed, Jan 21, 2015 at 4:03 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 21, 2015 at 3:16 PM, Chung-Kan Huang <ckhuangf at gmail.com>
> wrote:
>> On Wed, Jan 21, 2015 at 2:36 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Wed, Jan 21, 2015 at 2:29 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>>> wrote:
>>>> On Wed, Jan 21, 2015 at 2:15 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Wed, Jan 21, 2015 at 2:07 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>>>>> wrote:
>>>>>> On Wed, Jan 21, 2015 at 2:01 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, Jan 21, 2015 at 1:55 PM, Chung-Kan Huang <ckhuangf at gmail.com
>>>>>>> > wrote:
>>>>>>>> On Wed, Jan 21, 2015 at 1:44 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Wed, Jan 21, 2015 at 1:40 PM, Chung-Kan Huang <
>>>>>>>>> ckhuangf at gmail.com> wrote:
>>>>>>>>>> Then A & AB are not longer the same matrix.  They become complete
>>>>>>>>>> two individuals aren't they?
>>>>>>>>>> If I do whatever to AB after AB is created the A is still the
>>>>>>>>>> same old A and not going to be affected by the operations I do to AB.
>>>>>>>>> Yes.
>>>>>>>>>> What I am really looking for is a way to create two interfaces
>>>>>>>>>> (one as AIJ and one as BAIJ) but they both refer to the same matrix.
>>>>>>>>> Why would you ever want this? Why not just using BAIJ?
>>>>>>>> As I mentioned in the beginning.  There are parts of the code gets
>>>>>>>> benifit when AIJ is used and the other part gets benifit  if BAIJ is used.
>>>>>>>> For instance,
>>>>>>>> I'd like to use MatSetValuesBlocked but I also want to use ilu
>>>>>>>> constructed by AIJ instead of BAIJ (our experience found ilu from BAIJ
>>>>>>>> behaves funny sometimes.
>>>>>>> If the blocks truly are dense, then ILU(0) is identical on both.
>>>>>> Unfortunately the life is not that easy.  The blocks are spares and
>>>>>> we found ILU(1) works better for our case.
>>>>>> And besides that is not the only reason I want to have AIJ & BAIJ
>>>>>> interfaces, we have some code management issue and I am looking for short
>>>>>> cut to unite them.
>>>>>> So go back to the original question the short answer is no way?
>>>>> Yes, it would not make sense.
>>>>> What problem are you using ILU(1) for?
>>>> I am using it for flow simulation for reservoir problems.
>>> Have you considered trying algebraic multigrid?
>> I am solving PDE fully implicitly and as far as I know algebraic
>> multigrid only good for pressure equations
>> I will need 2 stages PC while AMG is for pressure stage but I will still
>> need something like ILU for second stage.
> So you are using a mixed-formulation of Darcy? What equations do you have?
After some steps of reduction, the system equation solved in linear solver
is basically the convervations of masses and energy.
Together I am solving the equations with natrual variables (pressure,
temperature, saturations and molar fractions) .
It might have variable block size depend on local state and physics that
considered.  For instant, I can skip mass transfer if it is impermeable to
fluid locally but I still need to solve for conduction in energy balance
equations.  I might also have some zones do not have some components so I
can skip them as well.  Ideally I should have used variable size of block
but I used the same size anyway in my previous BAIJ configuration as you
pointed out some optimization can be done with the same size blocked matrix.
I switched to AIJ for reason related to ILU that I explained already. I
didn't see the same problem in AIJ.
I am looking for room to improve linear solver performance in all aspects
including CPU time to assemble the matrix and also good PC that are
provided by PETSc.
Currently I am using AIJ + ILU(1) + overlay(1) +BCGS.  I am not so happy
about scalbility but that is not in the scope of the problem I brought
initially.  But I am interested if you have any good suggestions that I
should test.
Kan
>   Thanks,
>      MAtt
>>>> Some issues we found is that
>>>> 1) for a * x = 0 it doesn't return x = 0
>>> This is impossible. There must be a bug in the code.
>>>   Thanks,
>>>      Matt
>>>> 2) After compared ILU(1) with BAIJ against with ILU(1) with AIJ I found
>>>> latter one is better.  I could not find anything wrong with my BAIJ version
>>>> though.  However, experiences suggested that BAIJ's ILU(1) should be better.
>>>> Thanks,
>>>> Kan
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thanks,
>>>>>> Kan
>>>>>>>   Matt
>>>>>>>> Thanks,
>>>>>>>> Kan
>>>>>>>>>   Thanks,
>>>>>>>>>       Matt
>>>>>>>>>> Thanks,
>>>>>>>>>> Kan
>>>>>>>>>> On Wed, Jan 21, 2015 at 1:20 PM, Matthew Knepley <
>>>>>>>>>>> On Wed, Jan 21, 2015 at 12:56 PM, Chung-Kan Huang <
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> So if I do
>>>>>>>>>>>> Mat A, AB;
>>>>>>>>>>>> MatCreateAIJ(comm,m,n,M,N,d_nz, d_nnz,o_nz, o_nnz, &A);
>>>>>>>>>>>> MatConvert(A, MATBAIJ, MAT_INITAL_MATRIX, &AB);
>>>>>>>>>>>> MatSetBlockSize(AB, bs)
>>>>>>>>>>>> I can create AB as a BAIJ with block size of bs from A which is
>>>>>>>>>>>> a AIJ matrix.
>>>>>>>>>>>> So from this point I can use both A and AB and they will mean
>>>>>>>>>>>> the same matrix. Am I right?
>>>>>>>>>>> Yes
>>>>>>>>>>>> At the end of the program do I only destory one of them or both?
>>>>>>>>>>> Both
>>>>>>>>>>>> Do I need to worry about anything in terms of memory penalty?
>>>>>>>>>>> It is twice the memory. Its another matrix.
>>>>>>>>>>> Did you catch when Jed said you could jsut create the BAIJ up
>>>>>>>>>>> front?
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>     Matt
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Kan
>>>>>>>>>>>> On Tue, Jan 20, 2015 at 4:39 PM, Barry Smith <
>>>>>>>>>>>> bsmith at mcs.anl.gov> wrote:
>>>>>>>>>>>>>   You can do a MatConvert() (requires another copy of the
>>>>>>>>>>>>> matrix) for the parts that benefit from BAIJ.
>>>>>>>>>>>>>   Barry
>>>>>>>>>>>>> > On Jan 20, 2015, at 4:33 PM, Chung-Kan Huang <
>>>>>>>>>>>>> > Hi,
>>>>>>>>>>>>> > Does PETSc provide means for conversion between AIJ & BAIJ.
>>>>>>>>>>>>> > My matrix is created as AIJ because it makes life easy for
>>>>>>>>>>>>> most part of the applications but some part of applications actually get
>>>>>>>>>>>>> some benefits with BAIJ.  So I wonder if a matrix can exist as two
>>>>>>>>>>>>> idenfities and I can use either format depend on which one is more
>>>>>>>>>>>>> convenient at run time.
>>>>>>>>>>>>> > So in my case the block size is fixed and identical for all
>>>>>>>>>>>>> blocks.
>>>>>>>>>>>>> > Thanks,
>>>>>>>>>>>>> > Kan
>>>>>>>>>>>> *Cheers*
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> *Cheers*
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>> *Cheers*
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> *Cheers*
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> *Cheers*
>>> experiments lead.
>>> -- Norbert Wiener
>> *Cheers*
> experiments lead.
> -- Norbert Wiener
*Cheers*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150121/e888fa9a/attachment.html>
