[petsc-users] Conversion between AIJ & BAIJ
Wed Jan 21 16:03:14 CST 2015
On Wed, Jan 21, 2015 at 3:16 PM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> On Wed, Jan 21, 2015 at 2:36 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Jan 21, 2015 at 2:29 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>> wrote:
>>> On Wed, Jan 21, 2015 at 2:15 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Wed, Jan 21, 2015 at 2:07 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>>>> wrote:
>>>>> On Wed, Jan 21, 2015 at 2:01 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Wed, Jan 21, 2015 at 1:55 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, Jan 21, 2015 at 1:44 PM, Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Wed, Jan 21, 2015 at 1:40 PM, Chung-Kan Huang <
>>>>>>>>> Then A & AB are not longer the same matrix.  They become complete
>>>>>>>>> two individuals aren't they?
>>>>>>>>> If I do whatever to AB after AB is created the A is still the same
>>>>>>>>> old A and not going to be affected by the operations I do to AB.
>>>>>>>> Yes.
>>>>>>>>> What I am really looking for is a way to create two interfaces
>>>>>>>>> (one as AIJ and one as BAIJ) but they both refer to the same matrix.
>>>>>>>> Why would you ever want this? Why not just using BAIJ?
>>>>>>> As I mentioned in the beginning.  There are parts of the code gets
>>>>>>> benifit when AIJ is used and the other part gets benifit  if BAIJ is used.
>>>>>>> For instance,
>>>>>>> I'd like to use MatSetValuesBlocked but I also want to use ilu
>>>>>>> constructed by AIJ instead of BAIJ (our experience found ilu from BAIJ
>>>>>>> behaves funny sometimes.
>>>>>> If the blocks truly are dense, then ILU(0) is identical on both.
>>>>> Unfortunately the life is not that easy.  The blocks are spares and we
>>>>> found ILU(1) works better for our case.
>>>>> And besides that is not the only reason I want to have AIJ & BAIJ
>>>>> interfaces, we have some code management issue and I am looking for short
>>>>> cut to unite them.
>>>>> So go back to the original question the short answer is no way?
>>>> Yes, it would not make sense.
>>>> What problem are you using ILU(1) for?
>>> I am using it for flow simulation for reservoir problems.
>> Have you considered trying algebraic multigrid?
> I am solving PDE fully implicitly and as far as I know algebraic multigrid
> only good for pressure equations
> I will need 2 stages PC while AMG is for pressure stage but I will still
> need something like ILU for second stage.
So you are using a mixed-formulation of Darcy? What equations do you have?
     MAtt
>>> Some issues we found is that
>>> 1) for a * x = 0 it doesn't return x = 0
>> This is impossible. There must be a bug in the code.
>>   Thanks,
>>      Matt
>>> 2) After compared ILU(1) with BAIJ against with ILU(1) with AIJ I found
>>> latter one is better.  I could not find anything wrong with my BAIJ version
>>> though.  However, experiences suggested that BAIJ's ILU(1) should be better.
>>> Thanks,
>>> Kan
>>>>   Thanks,
>>>>      Matt
>>>>> Thanks,
>>>>> Kan
>>>>>>   Matt
>>>>>>> Thanks,
>>>>>>> Kan
>>>>>>>>   Thanks,
>>>>>>>>       Matt
>>>>>>>>> Thanks,
>>>>>>>>> Kan
>>>>>>>>> On Wed, Jan 21, 2015 at 1:20 PM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Wed, Jan 21, 2015 at 12:56 PM, Chung-Kan Huang <
>>>>>>>>>>> Hi,
>>>>>>>>>>> So if I do
>>>>>>>>>>> Mat A, AB;
>>>>>>>>>>> MatCreateAIJ(comm,m,n,M,N,d_nz, d_nnz,o_nz, o_nnz, &A);
>>>>>>>>>>> MatConvert(A, MATBAIJ, MAT_INITAL_MATRIX, &AB);
>>>>>>>>>>> MatSetBlockSize(AB, bs)
>>>>>>>>>>> I can create AB as a BAIJ with block size of bs from A which is
>>>>>>>>>>> a AIJ matrix.
>>>>>>>>>>> So from this point I can use both A and AB and they will mean
>>>>>>>>>>> the same matrix. Am I right?
>>>>>>>>>> Yes
>>>>>>>>>>> At the end of the program do I only destory one of them or both?
>>>>>>>>>> Both
>>>>>>>>>>> Do I need to worry about anything in terms of memory penalty?
>>>>>>>>>> It is twice the memory. Its another matrix.
>>>>>>>>>> Did you catch when Jed said you could jsut create the BAIJ up
>>>>>>>>>> front?
>>>>>>>>>>   Thanks,
>>>>>>>>>>     Matt
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Kan
>>>>>>>>>>> On Tue, Jan 20, 2015 at 4:39 PM, Barry Smith <bsmith at mcs.anl.gov
>>>>>>>>>>> > wrote:
>>>>>>>>>>>>   You can do a MatConvert() (requires another copy of the
>>>>>>>>>>>> matrix) for the parts that benefit from BAIJ.
>>>>>>>>>>>>   Barry
>>>>>>>>>>>> > On Jan 20, 2015, at 4:33 PM, Chung-Kan Huang <
>>>>>>>>>>>> > Hi,
>>>>>>>>>>>> > Does PETSc provide means for conversion between AIJ & BAIJ.
>>>>>>>>>>>> > My matrix is created as AIJ because it makes life easy for
>>>>>>>>>>>> most part of the applications but some part of applications actually get
>>>>>>>>>>>> some benefits with BAIJ.  So I wonder if a matrix can exist as two
>>>>>>>>>>>> idenfities and I can use either format depend on which one is more
>>>>>>>>>>>> convenient at run time.
>>>>>>>>>>>> > So in my case the block size is fixed and identical for all
>>>>>>>>>>>> blocks.
>>>>>>>>>>>> > Thanks,
>>>>>>>>>>>> > Kan
>>>>>>>>>>> *Cheers*
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> *Cheers*
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> *Cheers*
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> *Cheers*
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> *Cheers*
>> experiments lead.
>> -- Norbert Wiener
> *Cheers*
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150121/5162fc28/attachment-0001.html>
