[petsc-users] Conversion between AIJ & BAIJ
Wed Jan 21 13:20:20 CST 2015
On Wed, Jan 21, 2015 at 12:56 PM, Chung-Kan Huang <ckhuangf at gmail.com>
wrote:
> Hi,
> So if I do
> Mat A, AB;
> MatCreateAIJ(comm,m,n,M,N,d_nz, d_nnz,o_nz, o_nnz, &A);
> MatConvert(A, MATBAIJ, MAT_INITAL_MATRIX, &AB);
> MatSetBlockSize(AB, bs)
> I can create AB as a BAIJ with block size of bs from A which is a AIJ
> matrix.
> So from this point I can use both A and AB and they will mean the same
> matrix. Am I right?
Yes
> At the end of the program do I only destory one of them or both?
Both
> Do I need to worry about anything in terms of memory penalty?
It is twice the memory. Its another matrix.
Did you catch when Jed said you could jsut create the BAIJ up front?
    Matt
> Thanks,
> Kan
> On Tue, Jan 20, 2015 at 4:39 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   You can do a MatConvert() (requires another copy of the matrix) for the
>> parts that benefit from BAIJ.
>>   Barry
>> > On Jan 20, 2015, at 4:33 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>> wrote:
>> > Hi,
>> > Does PETSc provide means for conversion between AIJ & BAIJ.
>> > My matrix is created as AIJ because it makes life easy for most part of
>> the applications but some part of applications actually get some benefits
>> with BAIJ.  So I wonder if a matrix can exist as two idenfities and I can
>> use either format depend on which one is more convenient at run time.
>> > So in my case the block size is fixed and identical for all blocks.
>> > Thanks,
>> > Kan
> *Cheers*
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150121/6fe91db7/attachment.html>
