[petsc-users] Conversion between AIJ & BAIJ
Chung-Kan Huang
ckhuangf at gmail.com
Wed Jan 21 13:40:08 CST 2015
Then A & AB are not longer the same matrix. They become complete two
individuals aren't they?
If I do whatever to AB after AB is created the A is still the same old A
and not going to be affected by the operations I do to AB.
What I am really looking for is a way to create two interfaces (one as AIJ
and one as BAIJ) but they both refer to the same matrix.
Kan
On Wed, Jan 21, 2015 at 1:20 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 21, 2015 at 12:56 PM, Chung-Kan Huang <ckhuangf at gmail.com>
> wrote:
>> Hi,
>> So if I do
>> Mat A, AB;
>> MatCreateAIJ(comm,m,n,M,N,d_nz, d_nnz,o_nz, o_nnz, &A);
>> MatConvert(A, MATBAIJ, MAT_INITAL_MATRIX, &AB);
>> MatSetBlockSize(AB, bs)
>> I can create AB as a BAIJ with block size of bs from A which is a AIJ
>> matrix.
>> So from this point I can use both A and AB and they will mean the same
>> matrix. Am I right?
> Yes
>> At the end of the program do I only destory one of them or both?
> Both
>> Do I need to worry about anything in terms of memory penalty?
> It is twice the memory. Its another matrix.
> Did you catch when Jed said you could jsut create the BAIJ up front?
> Thanks,
> Matt
>> Thanks,
>> Kan
>> On Tue, Jan 20, 2015 at 4:39 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> You can do a MatConvert() (requires another copy of the matrix) for
>>> the parts that benefit from BAIJ.
>>> Barry
>>> > On Jan 20, 2015, at 4:33 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>>> wrote:
>>> > Hi,
>>> > Does PETSc provide means for conversion between AIJ & BAIJ.
>>> > My matrix is created as AIJ because it makes life easy for most part
>>> of the applications but some part of applications actually get some
>>> benefits with BAIJ. So I wonder if a matrix can exist as two idenfities
>>> and I can use either format depend on which one is more convenient at run
>>> time.
>>> > So in my case the block size is fixed and identical for all blocks.
>>> > Thanks,
>>> > Kan
>> *Cheers*
> experiments lead.
> -- Norbert Wiener
*Cheers*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150121/ff3cb32d/attachment-0001.html>
