[petsc-users] Conversion between AIJ & BAIJ
Wed Jan 21 13:19:55 CST 2015
> On Jan 21, 2015, at 12:56 PM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> Hi,
> So if I do
  You need to set the block size on the original matrix before you convert.
> Mat A, AB;
> MatCreateAIJ(comm,m,n,M,N,d_nz, d_nnz,o_nz, o_nnz, &A);
> MatConvert(A, MATBAIJ, MAT_INITAL_MATRIX, &AB);
> MatSetBlockSize(AB, bs)
> I can create AB as a BAIJ with block size of bs from A which is a AIJ matrix.
> So from this point I can use both A and AB and they will mean the same matrix. Am I right?
   They will have the same values but be different matrices and use different memory.
> At the end of the program do I only destory one of them or both?
  Both
> Do I need to worry about anything in terms of memory penalty?
   It uses roughly twice as much memory.
> Thanks,
> Kan
> On Tue, Jan 20, 2015 at 4:39 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   You can do a MatConvert() (requires another copy of the matrix) for the parts that benefit from BAIJ.
>   Barry
> > On Jan 20, 2015, at 4:33 PM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> > Hi,
> > Does PETSc provide means for conversion between AIJ & BAIJ.
> > My matrix is created as AIJ because it makes life easy for most part of the applications but some part of applications actually get some benefits with BAIJ.  So I wonder if a matrix can exist as two idenfities and I can use either format depend on which one is more convenient at run time.
> > So in my case the block size is fixed and identical for all blocks.
> > Thanks,
> > Kan
> Cheers
