[petsc-users] difference between DMDAVecGetArrayDOF and DMDAVecGetArray?
Gideon Simpson
gideon.simpson at gmail.com
Sat Feb 28 13:50:01 CST 2015
Supposing that I do not have a priori information as to the number of degrees of freedom per DA vertex; I want the number of mesh points along each sample path to be variable. Hence, I can’t really use a statically defined structure as you suggest. In that case, are the DOF routines the only option?
-gideon
> On Feb 28, 2015, at 2:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Feb 28, 2015 at 1:35 PM, Gideon Simpson <gideon.simpson at gmail.com <mailto:gideon.simpson at gmail.com>> wrote:
> I’m having some trouble understanding what the difference between these two routines are, though I am finding that there certainly is a difference. I have the following monte carlo problem. I am generating n_sample paths each of length n_points, and storing them in a 1D DA:
> DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE, n_samples, n_points, 0, NULL, &da);
> DMCreateGlobalVector(da,&paths_vec);
> When I then go to access them,
> PetscScalar **u_array;
> I find that:
> DMDAVecGetArrayDOF(da, paths_vec, &u_array);
> works as exepected, in that u_array[i] is a pointer to the first index of the i-th sample path, but if I call:
> DMDAVecGetArray(da, paths_vec, &u_array);
> u_array[i] is something else, and my attempts to manipulate it result in segmentation faults, even though the code compiles and builds.
> Suppose that you have 4 PetscScalar values at each vertex of the 1D DMDA. If you use
> PetscScalar **u;
> DMDAVecGetArrayDOF(da, uVec, &u);
> u[i][2] /* refers to 3rd scalar on vertex i */
> On the other hand you could use
> typedef struct {
> PetscScalar a, b, c, d;
> } Vals;
> Vals *u;
> DMDAVecGetArray(da, uVec, &u);
> u[i].c /* refers to the same value as above */
> Basically the DOF version gives you an extra level of indirection for the components.
> Thanks,
> Matt
> -gideon
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150228/fdcd40c7/attachment.html>
