[petsc-users] difference between DMDAVecGetArrayDOF and DMDAVecGetArray?
Sat Feb 28 13:54:14 CST 2015
On Sat, Feb 28, 2015 at 1:50 PM, Gideon Simpson <gideon.simpson at gmail.com>
wrote:
> Supposing that I do not have a priori information as to the number of
> degrees of freedom per DA vertex; I want the number of mesh points along
> each sample path to be variable.  Hence, I can’t really use a statically
> defined structure as you suggest.  In that case, are the DOF routines the
> only option?
DMDA just plain does not support that. It is close, but everything is not
hooked up right. If you have
variable numbers of unknowns per site, you can
  1) Fix DMDA with our help (demands programming)
  2) Use DMPlex (demands reading and maybe looking at code)
    Matt
> -gideon
> On Feb 28, 2015, at 2:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Feb 28, 2015 at 1:35 PM, Gideon Simpson <gideon.simpson at gmail.com>
> wrote:
>> I’m having some trouble understanding what the difference between these
>> two routines are, though I am finding that there certainly is a
>> difference.  I have the following monte carlo problem.  I am generating
>> n_sample paths each of length n_points, and storing them in a 1D DA:
>> DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE, n_samples, n_points, 0,
>> NULL, &da);
>> DMCreateGlobalVector(da,&paths_vec);
>> When I then go to access them,
>> PetscScalar **u_array;
>> I find that:
>> DMDAVecGetArrayDOF(da, paths_vec, &u_array);
>> works as exepected, in that u_array[i] is a pointer to the first index of
>> the i-th sample path, but if I call:
>> DMDAVecGetArray(da, paths_vec, &u_array);
>> u_array[i] is something else, and my attempts to manipulate it result in
>> segmentation faults, even though the code compiles and builds.
> Suppose that you have 4 PetscScalar values at each vertex of the 1D DMDA.
> If you use
>   PetscScalar **u;
>   DMDAVecGetArrayDOF(da, uVec, &u);
>   u[i][2] /* refers to 3rd scalar on vertex i */
> On the other hand you could use
> typedef struct {
>   PetscScalar a, b, c, d;
> } Vals;
>  Vals *u;
>  DMDAVecGetArray(da, uVec, &u);
>  u[i].c /* refers to the same value as above */
> Basically the DOF version gives you an extra level of indirection for the
> components.
>   Thanks,
>      Matt
>> -gideon
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150228/d00a74d8/attachment.html>
