[petsc-users] difference between DMDAVecGetArrayDOF and DMDAVecGetArray?
Matthew Knepley
knepley at gmail.com
Sat Feb 28 13:42:08 CST 2015
On Sat, Feb 28, 2015 at 1:35 PM, Gideon Simpson <gideon.simpson at gmail.com>
wrote:
> I’m having some trouble understanding what the difference between these
> two routines are, though I am finding that there certainly is a
> difference. I have the following monte carlo problem. I am generating
> n_sample paths each of length n_points, and storing them in a 1D DA:
> DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE, n_samples, n_points, 0,
> NULL, &da);
> DMCreateGlobalVector(da,&paths_vec);
> When I then go to access them,
> PetscScalar **u_array;
> I find that:
> DMDAVecGetArrayDOF(da, paths_vec, &u_array);
> works as exepected, in that u_array[i] is a pointer to the first index of
> the i-th sample path, but if I call:
> DMDAVecGetArray(da, paths_vec, &u_array);
> u_array[i] is something else, and my attempts to manipulate it result in
> segmentation faults, even though the code compiles and builds.
Suppose that you have 4 PetscScalar values at each vertex of the 1D DMDA.
If you use
PetscScalar **u;
DMDAVecGetArrayDOF(da, uVec, &u);
u[i][2] /* refers to 3rd scalar on vertex i */
On the other hand you could use
typedef struct {
PetscScalar a, b, c, d;
} Vals;
Vals *u;
DMDAVecGetArray(da, uVec, &u);
u[i].c /* refers to the same value as above */
Basically the DOF version gives you an extra level of indirection for the
components.
Matt
> -gideon
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150228/dc4a0da1/attachment.html>
