[petsc-users] MatMPIAIJSetPreallocation: "nnz cannot be greater than row length"
    Dmitry Karpeyev
    karpeev at mcs.anl.gov
    Mon Feb 23 09:40:09 CST 2015
Hi David,
Thanks -- I do see a failure with two mpi ranks.
libMesh needs to change the way configure extracts PETSc information --
configuration data were moved:
conf --> lib/petsc-conf
${PETSC_ARCH}/conf --> ${PETSC_ARCH}/lib/petsc-conf
At one point I started looking at m4/petsc.m4, but that got put on the back
burner.  For now making the relevant symlinks by hand lets you configure
and build libMesh with petsc/master.
Dmitry.
On Mon Feb 23 2015 at 9:15:44 AM David Knezevic <david.knezevic at akselos.com>
wrote:
> Hi Dmitry,
> Thanks very much for testing out the example.
> examples/systems_of_equations/ex8 works fine for me in serial, but it
> fails for me if I run with more than 1 MPI process. Can you try it with,
> say, 2 or 4 MPI processes?
> If we need access to MatReset in libMesh to get this to work, I'll be
> happy to work on a libMesh pull request for that.
> David
> David J. Knezevic | CTO
> Akselos | 17 Bay State Road | Boston, MA | 02215
> Phone (office): +1-857-265-2238
> Phone (mobile): +1-617-599-4755
> Web: http://www.akselos.com
> On Mon, Feb 23, 2015 at 10:08 AM, Dmitry Karpeyev <karpeev at mcs.anl.gov>
> wrote:
>> David,
>> What code are you running when you encounter this error?  I'm trying to
>> reproduce it and
>> I tried examples/systems_of_equations/ex8, but it ran for me, ostensibly
>> to completion.
>> I have a small PETSc pull request that implements MatReset(), which
>> passes a small PETSc test,
>> but libMesh needs some work to be able to build against petsc/master
>> because of some recent
>> changes to PETSc.
>> Dmitry.
>> On Mon Feb 23 2015 at 7:17:06 AM David Knezevic <
>> david.knezevic at akselos.com> wrote:
>>> Hi Barry, hi Dmitry,
>>> I set the matrix to BAIJ and back to AIJ, and the code got a bit
>>> further. But I now run into the error pasted below (Note that I'm now using
>>> "--with-debugging=1"):
>>> PETSC ERROR: --------------------- Error Message
>>> PETSC ERROR: Petsc has generated inconsistent data
>>> PETSC ERROR: MPIAIJ Matrix was assembled but is missing garray
>>> PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
>>> PETSC ERROR: ./example-dbg on a arch-linux2-c-debug named david-Lenovo
>>> by dknez Mon Feb 23 08:05:44 2015
>>> PETSC ERROR: Configure options --with-shared-libraries=1
>>> --with-debugging=1 --download-suitesparse=1 --download-parmetis=1
>>> --download-blacs=1 --download-scalapack=1 --download-mumps=1
>>> --download-metis --download-superlu_dist --prefix=/home/dknez/software/libmesh_install/dbg_real/petsc
>>> --download-hypre
>>> PETSC ERROR: #1 MatCreateColmap_MPIAIJ_Private() line 361 in
>>> /home/dknez/software/petsc-3.5.2/src/mat/impls/aij/mpi/mpiaij.c
>>> PETSC ERROR: #2 MatSetValues_MPIAIJ() line 538 in
>>> PETSC ERROR: #3 MatSetValues() line 1136 in /home/dknez/software/petsc-3.
>>> 5.2/src/mat/interface/matrix.c
>>> PETSC ERROR: #4 add_matrix() line 765 in /home/dknez/software/libmesh-
>>> src/src/numerics/petsc_matrix.C
>>> This occurs when I try to set some entries of the matrix. Do you have
>>> any suggestions on how I can resolve this?
>>> Thanks!
>>> David
>>> On Sun, Feb 22, 2015 at 10:22 PM, Dmitry Karpeyev <dkarpeev at gmail.com>
>>> wrote:
>>>> On Sun Feb 22 2015 at 9:15:22 PM Barry Smith <bsmith at mcs.anl.gov>
>>>> wrote:
>>>>> > On Feb 22, 2015, at 9:09 PM, David Knezevic <
>>>>> > Hi Dmitry,
>>>>> > Thanks for the suggestion. I tried MatSetType(mat,MATMPIAIJ)
>>>>> followed by MatXAIJSetPreallocation(...), but unfortunately this still
>>>>> gives me the same error as before: "nnz cannot be greater than row length:
>>>>> local row 168 value 24 rowlength 0".
>>>>> > I gather that the idea here is that MatSetType builds a new matrix
>>>>> object, and then I should be able to pre-allocate for that new matrix
>>>>> however I like, right? Was I supposed to clear the matrix object somehow
>>>>> before calling MatSetType? (I didn't do any sort of clear operation.)
>>>>>   If the type doesn't change then MatSetType() won't do anything. You
>>>>> can try setting the type to BAIJ and then setting the type back to AIJ.
>>>>> This may/should clear out the matrix.
>>>> Ah, yes.  If the type is the same as before it does quit early, but
>>>> changing the type and then back will clear out and rebuild the matrix.   We
>>>> need
>>>> something like MatReset() to do the equivalent thing.
>>>>> > As I said earlier, I'll make a dbg PETSc build, so hopefully that
>>>>> will help shed some light on what's going wrong for me.
>>>> I think it's always a good idea to have a dbg build of PETSc when you
>>>> doing things like these.
>>>> Dmitry.
>>>>>    Don't bother, what I suggested won't work.
>>>>>   Barry
>>>>> > Thanks,
>>>>> > David
>>>>> > On Sun, Feb 22, 2015 at 6:02 PM, Dmitry Karpeyev <dkarpeev at gmail.com>
>>>>> wrote:
>>>>> > David,
>>>>> > It might be easier to just rebuild the whole matrix from scratch:
>>>>> you would in effect be doing all that with disassembling and resetting the
>>>>> preallocation.
>>>>> > or
>>>>> > PetscObjectGetType((PetscObject)mat,&type);
>>>>> > MatSetType(mat,type);
>>>>> > followed by
>>>>> > MatXAIJSetPreallocation(...);
>>>>> > should do.
>>>>> > Dmitry.
>>>>> > On Sun Feb 22 2015 at 4:45:46 PM Barry Smith <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>> >  Do not call for SeqAIJ matrix. Do not call before the first time
>>>>> you have preallocated and put entries in the matrix and done the
>>>>> MatAssemblyBegin/End()
>>>>> >   If it still crashes you'll need to try the debugger
>>>>> >   Barry
>>>>> > > On Feb 22, 2015, at 4:09 PM, David Knezevic <
>>>>> > > Hi Barry,
>>>>> > > Thanks for your help, much appreciated.
>>>>> > > I added a prototype for MatDisAssemble_MPIAIJ:
>>>>> > > PETSC_INTERN PetscErrorCode MatDisAssemble_MPIAIJ(Mat);
>>>>> > > and I added a call to MatDisAssemble_MPIAIJ before
>>>>> MatMPIAIJSetPreallocation. However, I get a segfault on the call to
>>>>> MatDisAssemble_MPIAIJ. The segfault occurs in both serial and parallel.
>>>>> > > FYI, I'm using Petsc 3.5.2, and I'm not using a non-debug build
>>>>> (though I could rebuild PETSc in debug mode if you think that would help
>>>>> figure out what's happening here).
>>>>> > > Thanks,
>>>>> > > David
>>>>> > > On Sun, Feb 22, 2015 at 1:13 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>> > >   David,
>>>>> > >    This is an obscure little feature of MatMPIAIJ,   each time you
>>>>> change the sparsity pattern before you call the MatMPIAIJSetPreallocation
>>>>> you need to call  MatDisAssemble_MPIAIJ(Mat mat).    This is a private
>>>>> PETSc function so you need to provide your own prototype for it above the
>>>>> function you use it in.
>>>>> > >   Let us know if this resolves the problem.
>>>>> > >    Barry
>>>>> > > We never really intended that people would call
>>>>> MatMPIAIJSetPreallocation() AFTER they had already used the matrix.
>>>>> > > > On Feb 22, 2015, at 6:50 AM, David Knezevic <
>>>>> > > > Hi all,
>>>>> > > > I've implemented a solver for a contact problem using SNES. The
>>>>> sparsity pattern of the jacobian matrix needs to change at each nonlinear
>>>>> iteration (because the elements which are in contact can change), so I
>>>>> tried to deal with this by calling MatSeqAIJSetPreallocation and
>>>>> MatMPIAIJSetPreallocation during each iteration in order to update the
>>>>> preallocation.
>>>>> > > > This seems to work fine in serial, but with two or more MPI
>>>>> processes I run into the error "nnz cannot be greater than row length",
>>>>> e.g.:
>>>>> > > > nnz cannot be greater than row length: local row 528 value 12
>>>>> rowlength 0
>>>>> > > > This error is from the call to
>>>>> > > > MatSeqAIJSetPreallocation(b->B,o_nz,o_nnz); in
>>>>> MatMPIAIJSetPreallocation_MPIAIJ.
>>>>> > > > Any guidance on what the problem might be would be most
>>>>> appreciated. For example, I was wondering if there is a problem with
>>>>> calling SetPreallocation on a matrix that has already been preallocated?
>>>>> > > > Some notes:
>>>>> > > > - I'm using PETSc via libMesh
>>>>> > > > - The code that triggers this issue is available as a PR on the
>>>>> libMesh github repo, in case anyone is interested:
>>>>> https://github.com/libMesh/libmesh/pull/460/
>>>>> > > > - I can try to make a minimal pure-PETSc example that reproduces
>>>>> this error, if that would be helpful.
>>>>> > > > Many thanks,
>>>>> > > > David
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150223/7ef48c96/attachment-0001.html>
