[petsc-users] MatMPIAIJSetPreallocation: "nnz cannot be greater than row length"
    David Knezevic
    david.knezevic at akselos.com
    Mon Feb 23 10:03:25 CST 2015
Hi Dmitry,
OK, good to hear we're seeing the same behavior for the example.
Regarding this comment:
libMesh needs to change the way configure extracts PETSc information --
> configuration data were moved:
> conf --> lib/petsc-conf
> ${PETSC_ARCH}/conf --> ${PETSC_ARCH}/lib/petsc-conf
> At one point I started looking at m4/petsc.m4, but that got put on the
> back burner.  For now making the relevant symlinks by hand lets you
> configure and build libMesh with petsc/master.
So do you suggest that the next step here is to build libmesh against
petsc/master so that we can try your PETSc pull request that implements
MatReset() to see if that gets this example working?
David
> On Mon Feb 23 2015 at 9:15:44 AM David Knezevic <
> david.knezevic at akselos.com> wrote:
>> Hi Dmitry,
>> Thanks very much for testing out the example.
>> examples/systems_of_equations/ex8 works fine for me in serial, but it
>> fails for me if I run with more than 1 MPI process. Can you try it with,
>> say, 2 or 4 MPI processes?
>> If we need access to MatReset in libMesh to get this to work, I'll be
>> happy to work on a libMesh pull request for that.
>> David
>> David J. Knezevic | CTO
>> Akselos | 17 Bay State Road | Boston, MA | 02215
>> Phone (office): +1-857-265-2238
>> Phone (mobile): +1-617-599-4755
>> Web: http://www.akselos.com
>> On Mon, Feb 23, 2015 at 10:08 AM, Dmitry Karpeyev <karpeev at mcs.anl.gov>
>> wrote:
>>> David,
>>> What code are you running when you encounter this error?  I'm trying to
>>> reproduce it and
>>> I tried examples/systems_of_equations/ex8, but it ran for me,
>>> ostensibly to completion.
>>> I have a small PETSc pull request that implements MatReset(), which
>>> passes a small PETSc test,
>>> but libMesh needs some work to be able to build against petsc/master
>>> because of some recent
>>> changes to PETSc.
>>> Dmitry.
>>> On Mon Feb 23 2015 at 7:17:06 AM David Knezevic <
>>>> Hi Barry, hi Dmitry,
>>>> I set the matrix to BAIJ and back to AIJ, and the code got a bit
>>>> further. But I now run into the error pasted below (Note that I'm now using
>>>> "--with-debugging=1"):
>>>> PETSC ERROR: --------------------- Error Message
>>>> PETSC ERROR: Petsc has generated inconsistent data
>>>> PETSC ERROR: MPIAIJ Matrix was assembled but is missing garray
>>>> PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for trouble shooting.
>>>> PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
>>>> PETSC ERROR: ./example-dbg on a arch-linux2-c-debug named david-Lenovo
>>>> by dknez Mon Feb 23 08:05:44 2015
>>>> PETSC ERROR: Configure options --with-shared-libraries=1
>>>> --with-debugging=1 --download-suitesparse=1 --download-parmetis=1
>>>> --download-blacs=1 --download-scalapack=1 --download-mumps=1
>>>> --download-metis --download-superlu_dist --prefix=/home/dknez/software/libmesh_install/dbg_real/petsc
>>>> --download-hypre
>>>> PETSC ERROR: #1 MatCreateColmap_MPIAIJ_Private() line 361 in
>>>> /home/dknez/software/petsc-3.5.2/src/mat/impls/aij/mpi/mpiaij.c
>>>> PETSC ERROR: #2 MatSetValues_MPIAIJ() line 538 in
>>>> PETSC ERROR: #3 MatSetValues() line 1136 in
>>>> /home/dknez/software/petsc-3.5.2/src/mat/interface/matrix.c
>>>> PETSC ERROR: #4 add_matrix() line 765 in /home/dknez/software/libmesh-
>>>> src/src/numerics/petsc_matrix.C
>>>> This occurs when I try to set some entries of the matrix. Do you have
>>>> any suggestions on how I can resolve this?
>>>> Thanks!
>>>> David
>>>> On Sun, Feb 22, 2015 at 10:22 PM, Dmitry Karpeyev <dkarpeev at gmail.com>
>>>> wrote:
>>>>> On Sun Feb 22 2015 at 9:15:22 PM Barry Smith <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>>> > On Feb 22, 2015, at 9:09 PM, David Knezevic <
>>>>>> > Hi Dmitry,
>>>>>> > Thanks for the suggestion. I tried MatSetType(mat,MATMPIAIJ)
>>>>>> followed by MatXAIJSetPreallocation(...), but unfortunately this still
>>>>>> gives me the same error as before: "nnz cannot be greater than row length:
>>>>>> local row 168 value 24 rowlength 0".
>>>>>> > I gather that the idea here is that MatSetType builds a new matrix
>>>>>> object, and then I should be able to pre-allocate for that new matrix
>>>>>> however I like, right? Was I supposed to clear the matrix object somehow
>>>>>> before calling MatSetType? (I didn't do any sort of clear operation.)
>>>>>>   If the type doesn't change then MatSetType() won't do anything. You
>>>>>> can try setting the type to BAIJ and then setting the type back to AIJ.
>>>>>> This may/should clear out the matrix.
>>>>> Ah, yes.  If the type is the same as before it does quit early, but
>>>>> changing the type and then back will clear out and rebuild the matrix.   We
>>>>> need
>>>>> something like MatReset() to do the equivalent thing.
>>>>>> > As I said earlier, I'll make a dbg PETSc build, so hopefully that
>>>>>> will help shed some light on what's going wrong for me.
>>>>> I think it's always a good idea to have a dbg build of PETSc when you
>>>>> doing things like these.
>>>>> Dmitry.
>>>>>>    Don't bother, what I suggested won't work.
>>>>>>   Barry
>>>>>> > Thanks,
>>>>>> > David
>>>>>> > On Sun, Feb 22, 2015 at 6:02 PM, Dmitry Karpeyev <
>>>>>> dkarpeev at gmail.com> wrote:
>>>>>> > David,
>>>>>> > It might be easier to just rebuild the whole matrix from scratch:
>>>>>> you would in effect be doing all that with disassembling and resetting the
>>>>>> preallocation.
>>>>>> > or
>>>>>> > PetscObjectGetType((PetscObject)mat,&type);
>>>>>> > MatSetType(mat,type);
>>>>>> > followed by
>>>>>> > MatXAIJSetPreallocation(...);
>>>>>> > should do.
>>>>>> > Dmitry.
>>>>>> > On Sun Feb 22 2015 at 4:45:46 PM Barry Smith <bsmith at mcs.anl.gov>
>>>>>> wrote:
>>>>>> >  Do not call for SeqAIJ matrix. Do not call before the first time
>>>>>> you have preallocated and put entries in the matrix and done the
>>>>>> MatAssemblyBegin/End()
>>>>>> >   If it still crashes you'll need to try the debugger
>>>>>> >   Barry
>>>>>> > > On Feb 22, 2015, at 4:09 PM, David Knezevic <
>>>>>> > > Hi Barry,
>>>>>> > > Thanks for your help, much appreciated.
>>>>>> > > I added a prototype for MatDisAssemble_MPIAIJ:
>>>>>> > > PETSC_INTERN PetscErrorCode MatDisAssemble_MPIAIJ(Mat);
>>>>>> > > and I added a call to MatDisAssemble_MPIAIJ before
>>>>>> MatMPIAIJSetPreallocation. However, I get a segfault on the call to
>>>>>> MatDisAssemble_MPIAIJ. The segfault occurs in both serial and parallel.
>>>>>> > > FYI, I'm using Petsc 3.5.2, and I'm not using a non-debug build
>>>>>> (though I could rebuild PETSc in debug mode if you think that would help
>>>>>> figure out what's happening here).
>>>>>> > > Thanks,
>>>>>> > > David
>>>>>> > > On Sun, Feb 22, 2015 at 1:13 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>> wrote:
>>>>>> > >   David,
>>>>>> > >    This is an obscure little feature of MatMPIAIJ,   each time
>>>>>> you change the sparsity pattern before you call the
>>>>>> MatMPIAIJSetPreallocation you need to call  MatDisAssemble_MPIAIJ(Mat
>>>>>> mat).    This is a private PETSc function so you need to provide your own
>>>>>> prototype for it above the function you use it in.
>>>>>> > >   Let us know if this resolves the problem.
>>>>>> > >    Barry
>>>>>> > > We never really intended that people would call
>>>>>> MatMPIAIJSetPreallocation() AFTER they had already used the matrix.
>>>>>> > > > On Feb 22, 2015, at 6:50 AM, David Knezevic <
>>>>>> > > > Hi all,
>>>>>> > > > I've implemented a solver for a contact problem using SNES. The
>>>>>> sparsity pattern of the jacobian matrix needs to change at each nonlinear
>>>>>> iteration (because the elements which are in contact can change), so I
>>>>>> tried to deal with this by calling MatSeqAIJSetPreallocation and
>>>>>> MatMPIAIJSetPreallocation during each iteration in order to update the
>>>>>> preallocation.
>>>>>> > > > This seems to work fine in serial, but with two or more MPI
>>>>>> processes I run into the error "nnz cannot be greater than row length",
>>>>>> e.g.:
>>>>>> > > > nnz cannot be greater than row length: local row 528 value 12
>>>>>> rowlength 0
>>>>>> > > > This error is from the call to
>>>>>> > > > MatSeqAIJSetPreallocation(b->B,o_nz,o_nnz); in
>>>>>> MatMPIAIJSetPreallocation_MPIAIJ.
>>>>>> > > > Any guidance on what the problem might be would be most
>>>>>> appreciated. For example, I was wondering if there is a problem with
>>>>>> calling SetPreallocation on a matrix that has already been preallocated?
>>>>>> > > > Some notes:
>>>>>> > > > - I'm using PETSc via libMesh
>>>>>> > > > - The code that triggers this issue is available as a PR on the
>>>>>> libMesh github repo, in case anyone is interested:
>>>>>> https://github.com/libMesh/libmesh/pull/460/
>>>>>> > > > - I can try to make a minimal pure-PETSc example that
>>>>>> reproduces this error, if that would be helpful.
>>>>>> > > > Many thanks,
>>>>>> > > > David
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150223/ee2fc100/attachment.html>
