[petsc-users] MatMPIAIJSetPreallocation: "nnz cannot be greater than row length"
    David Knezevic
    david.knezevic at akselos.com
    Mon Feb 23 09:15:37 CST 2015
Hi Dmitry,
Thanks very much for testing out the example.
examples/systems_of_equations/ex8 works fine for me in serial, but it fails
for me if I run with more than 1 MPI process. Can you try it with, say, 2
or 4 MPI processes?
If we need access to MatReset in libMesh to get this to work, I'll be happy
to work on a libMesh pull request for that.
David
David J. Knezevic | CTO
Akselos | 17 Bay State Road | Boston, MA | 02215
Phone (office): +1-857-265-2238
Phone (mobile): +1-617-599-4755
Web: http://www.akselos.com
On Mon, Feb 23, 2015 at 10:08 AM, Dmitry Karpeyev <karpeev at mcs.anl.gov>
wrote:
> David,
> What code are you running when you encounter this error?  I'm trying to
> reproduce it and
> I tried examples/systems_of_equations/ex8, but it ran for me, ostensibly
> to completion.
> I have a small PETSc pull request that implements MatReset(), which passes
> a small PETSc test,
> but libMesh needs some work to be able to build against petsc/master
> because of some recent
> changes to PETSc.
> Dmitry.
> On Mon Feb 23 2015 at 7:17:06 AM David Knezevic <
> david.knezevic at akselos.com> wrote:
>> Hi Barry, hi Dmitry,
>> I set the matrix to BAIJ and back to AIJ, and the code got a bit further.
>> But I now run into the error pasted below (Note that I'm now using
>> "--with-debugging=1"):
>> PETSC ERROR: --------------------- Error Message
>> PETSC ERROR: Petsc has generated inconsistent data
>> PETSC ERROR: MPIAIJ Matrix was assembled but is missing garray
>> PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
>> trouble shooting.
>> PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
>> PETSC ERROR: ./example-dbg on a arch-linux2-c-debug named david-Lenovo by
>> dknez Mon Feb 23 08:05:44 2015
>> PETSC ERROR: Configure options --with-shared-libraries=1
>> --with-debugging=1 --download-suitesparse=1 --download-parmetis=1
>> --download-blacs=1 --download-scalapack=1 --download-mumps=1
>> --download-metis --download-superlu_dist
>> --prefix=/home/dknez/software/libmesh_install/dbg_real/petsc
>> --download-hypre
>> PETSC ERROR: #1 MatCreateColmap_MPIAIJ_Private() line 361 in
>> /home/dknez/software/petsc-3.5.2/src/mat/impls/aij/mpi/mpiaij.c
>> PETSC ERROR: #2 MatSetValues_MPIAIJ() line 538 in
>> PETSC ERROR: #3 MatSetValues() line 1136 in
>> /home/dknez/software/petsc-3.5.2/src/mat/interface/matrix.c
>> PETSC ERROR: #4 add_matrix() line 765 in
>> /home/dknez/software/libmesh-src/src/numerics/petsc_matrix.C
>> This occurs when I try to set some entries of the matrix. Do you have any
>> suggestions on how I can resolve this?
>> Thanks!
>> David
>> On Sun, Feb 22, 2015 at 10:22 PM, Dmitry Karpeyev <dkarpeev at gmail.com>
>> wrote:
>>> On Sun Feb 22 2015 at 9:15:22 PM Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> > On Feb 22, 2015, at 9:09 PM, David Knezevic <
>>>> > Hi Dmitry,
>>>> > Thanks for the suggestion. I tried MatSetType(mat,MATMPIAIJ) followed
>>>> by MatXAIJSetPreallocation(...), but unfortunately this still gives me the
>>>> same error as before: "nnz cannot be greater than row length: local row 168
>>>> value 24 rowlength 0".
>>>> > I gather that the idea here is that MatSetType builds a new matrix
>>>> object, and then I should be able to pre-allocate for that new matrix
>>>> however I like, right? Was I supposed to clear the matrix object somehow
>>>> before calling MatSetType? (I didn't do any sort of clear operation.)
>>>>   If the type doesn't change then MatSetType() won't do anything. You
>>>> can try setting the type to BAIJ and then setting the type back to AIJ.
>>>> This may/should clear out the matrix.
>>> Ah, yes.  If the type is the same as before it does quit early, but
>>> changing the type and then back will clear out and rebuild the matrix.   We
>>> need
>>> something like MatReset() to do the equivalent thing.
>>>> > As I said earlier, I'll make a dbg PETSc build, so hopefully that
>>>> will help shed some light on what's going wrong for me.
>>> I think it's always a good idea to have a dbg build of PETSc when you
>>> doing things like these.
>>> Dmitry.
>>>>    Don't bother, what I suggested won't work.
>>>>   Barry
>>>> > Thanks,
>>>> > David
>>>> > On Sun, Feb 22, 2015 at 6:02 PM, Dmitry Karpeyev <dkarpeev at gmail.com>
>>>> wrote:
>>>> > David,
>>>> > It might be easier to just rebuild the whole matrix from scratch: you
>>>> would in effect be doing all that with disassembling and resetting the
>>>> preallocation.
>>>> > or
>>>> > PetscObjectGetType((PetscObject)mat,&type);
>>>> > MatSetType(mat,type);
>>>> > followed by
>>>> > MatXAIJSetPreallocation(...);
>>>> > should do.
>>>> > Dmitry.
>>>> > On Sun Feb 22 2015 at 4:45:46 PM Barry Smith <bsmith at mcs.anl.gov>
>>>> wrote:
>>>> >  Do not call for SeqAIJ matrix. Do not call before the first time you
>>>> have preallocated and put entries in the matrix and done the
>>>> MatAssemblyBegin/End()
>>>> >   If it still crashes you'll need to try the debugger
>>>> >   Barry
>>>> > > On Feb 22, 2015, at 4:09 PM, David Knezevic <
>>>> > > Hi Barry,
>>>> > > Thanks for your help, much appreciated.
>>>> > > I added a prototype for MatDisAssemble_MPIAIJ:
>>>> > > PETSC_INTERN PetscErrorCode MatDisAssemble_MPIAIJ(Mat);
>>>> > > and I added a call to MatDisAssemble_MPIAIJ before
>>>> MatMPIAIJSetPreallocation. However, I get a segfault on the call to
>>>> MatDisAssemble_MPIAIJ. The segfault occurs in both serial and parallel.
>>>> > > FYI, I'm using Petsc 3.5.2, and I'm not using a non-debug build
>>>> (though I could rebuild PETSc in debug mode if you think that would help
>>>> figure out what's happening here).
>>>> > > Thanks,
>>>> > > David
>>>> > > On Sun, Feb 22, 2015 at 1:13 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>> wrote:
>>>> > >   David,
>>>> > >    This is an obscure little feature of MatMPIAIJ,   each time you
>>>> change the sparsity pattern before you call the MatMPIAIJSetPreallocation
>>>> you need to call  MatDisAssemble_MPIAIJ(Mat mat).    This is a private
>>>> PETSc function so you need to provide your own prototype for it above the
>>>> function you use it in.
>>>> > >   Let us know if this resolves the problem.
>>>> > >    Barry
>>>> > > We never really intended that people would call
>>>> MatMPIAIJSetPreallocation() AFTER they had already used the matrix.
>>>> > > > On Feb 22, 2015, at 6:50 AM, David Knezevic <
>>>> > > > Hi all,
>>>> > > > I've implemented a solver for a contact problem using SNES. The
>>>> sparsity pattern of the jacobian matrix needs to change at each nonlinear
>>>> iteration (because the elements which are in contact can change), so I
>>>> tried to deal with this by calling MatSeqAIJSetPreallocation and
>>>> MatMPIAIJSetPreallocation during each iteration in order to update the
>>>> preallocation.
>>>> > > > This seems to work fine in serial, but with two or more MPI
>>>> processes I run into the error "nnz cannot be greater than row length",
>>>> e.g.:
>>>> > > > nnz cannot be greater than row length: local row 528 value 12
>>>> rowlength 0
>>>> > > > This error is from the call to
>>>> > > > MatSeqAIJSetPreallocation(b->B,o_nz,o_nnz); in
>>>> MatMPIAIJSetPreallocation_MPIAIJ.
>>>> > > > Any guidance on what the problem might be would be most
>>>> appreciated. For example, I was wondering if there is a problem with
>>>> calling SetPreallocation on a matrix that has already been preallocated?
>>>> > > > Some notes:
>>>> > > > - I'm using PETSc via libMesh
>>>> > > > - The code that triggers this issue is available as a PR on the
>>>> libMesh github repo, in case anyone is interested:
>>>> https://github.com/libMesh/libmesh/pull/460/
>>>> > > > - I can try to make a minimal pure-PETSc example that reproduces
>>>> this error, if that would be helpful.
>>>> > > > Many thanks,
>>>> > > > David
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150223/1c75b0ba/attachment-0001.html>
