[petsc-users] GAMG having very large coarse problem?
Mark Adams mfadams at lbl.gov
Fri Feb 20 11:05:40 CST 2015
Not sure what is going on.  It stopped coarsening for some reason.  Does
the code set the number of levels at 2?  Could you try remove the
-pc_gamg_coarse_eq_limit
200 ... maybe it is gett junk.  Also add -pc_gamg_verbose 2.  That might
give me a clue (probably not).
On Wed, Feb 18, 2015 at 10:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Mark,
>    When I run ksp/ksp/examples/tutorials/ex45 I get a VERY large coarse
> problem. It seems to ignore the -pc_gamg_coarse_eq_limit 200 argument. Any
> idea what is going on?
>    Thanks
>     Barry
> $ ./ex45 -da_refine 3 -pc_type gamg -ksp_monitor -ksp_view -log_summary
>   0 KSP Residual norm 2.790769524030e+02
>   1 KSP Residual norm 4.484052193577e+01
>   2 KSP Residual norm 2.409368790441e+00
>   3 KSP Residual norm 1.553421589919e-01
>   4 KSP Residual norm 9.821441923699e-03
>   5 KSP Residual norm 5.610434857134e-04
> KSP Object: 1 MPI processes
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>   left preconditioning
>   using nonzero initial guess
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: gamg
>     MG: type is MULTIPLICATIVE, levels=2 cycles=v
>       Cycles per PCApply=1
>       Using Galerkin computed coarse grid matrices
>   Coarse grid solver -- level -------------------------------
>     KSP Object:    (mg_coarse_)     1 MPI processes
>       type: gmres
>       maximum iterations=1, initial guess is zero
>       using NONE norm type for convergence test
>     PC Object:    (mg_coarse_)     1 MPI processes
>       type: bjacobi
>         block Jacobi: number of blocks = 1
>         Local solve is same for all blocks, in the following KSP and PC
> objects:
>         KSP Object:        (mg_coarse_sub_)         1 MPI processes
>           type: preonly
>         PC Object:        (mg_coarse_sub_)         1 MPI processes
>           type: lu
>             LU: out-of-place factorization
>             tolerance for zero pivot 2.22045e-14
>             using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>             matrix ordering: nd
>             factor fill ratio given 5, needed 36.4391
>               Factored matrix follows:
>                 Mat Object:                 1 MPI processes
>                   type: seqaij
>                   rows=16587, cols=16587
>                   package used to perform factorization: petsc
>                   total: nonzeros=1.8231e+07, allocated nonzeros=1.8231e+07
>                   total number of mallocs used during MatSetValues calls =0
>                     not using I-node routines
>           linear system matrix = precond matrix:
>             type: seqaij
>             total: nonzeros=500315, allocated nonzeros=500315
>         type: seqaij
>   Down solver (pre-smoother) on level 1 -------------------------------
>     KSP Object:    (mg_levels_1_)     1 MPI processes
>       type: chebyshev
>         Chebyshev: eigenvalue estimates:  min = 0.0976343, max = 2.05032
>       maximum iterations=2
>     PC Object:    (mg_levels_1_)     1 MPI processes
>       type: sor
>         SOR: type = local_symmetric, iterations = 1, local iterations = 1,
> omega = 1
>         type: seqaij
>         rows=117649, cols=117649
>         total: nonzeros=809137, allocated nonzeros=809137
>   Up solver (post-smoother) same as down solver (pre-smoother)
>     type: seqaij
> Residual norm 3.81135e-05
> ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
> -fCourier9' to print this document            ***
> ---------------------------------------------- PETSc Performance Summary:
> ./ex45 on a arch-opt named Barrys-MacBook-Pro.local with 1 processor, by
> barrysmith Wed Feb 18 21:38:03 2015
> Using Petsc Development GIT revision: v3.5.3-1998-geddef31  GIT Date:
> 2015-02-18 11:05:09 -0600
>                          Max       Max/Min        Avg      Total
> Time (sec):           1.103e+01      1.00000   1.103e+01
> Objects:              9.200e+01      1.00000   9.200e+01
> Flops:                1.756e+10      1.00000   1.756e+10  1.756e+10
> Flops/sec:            1.592e+09      1.00000   1.592e+09  1.592e+09
> MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
> MPI Reductions:       0.000e+00      0.00000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
>                             e.g., VecAXPY() for real vectors of length N
> --> 2N flops
>                             and VecAXPY() for complex vectors of length N
> --> 8N flops
> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
> ---  -- Message Lengths --  -- Reductions --
>                         Avg     %Total     Avg     %Total   counts
>  %Total     Avg         %Total   counts   %Total
>  0:      Main Stage: 1.1030e+01 100.0%  1.7556e+10 100.0%  0.000e+00
>  0.0%  0.000e+00        0.0%  0.000e+00   0.0%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
>    Count: number of times phase was executed
>    Time and Flops: Max - maximum over all processors
>                    Ratio - ratio of maximum to minimum over all processors
>    Mess: number of messages sent
>    Avg. len: average message length (bytes)
>    Reduct: number of global reductions
>    Global: entire computation
>    Stage: stages of a computation. Set stages with PetscLogStagePush() and
> PetscLogStagePop().
>       %T - percent time in this phase         %F - percent flops in this
> phase
>       %M - percent messages in this phase     %L - percent message lengths
> in this phase
>       %R - percent reductions in this phase
>    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
> Event                Count      Time (sec)     Flops
>        --- Global ---  --- Stage ---   Total
>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> KSPGMRESOrthog        21 1.0 8.8868e-03 1.0 3.33e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  3752
> KSPSetUp               5 1.0 4.3986e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> KSPSolve               1 1.0 1.0995e+01 1.0 1.76e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00100100  0  0  0 100100  0  0  0  1596
> VecMDot               21 1.0 4.7335e-03 1.0 1.67e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  3522
> VecNorm               30 1.0 9.4804e-04 1.0 4.63e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  4887
> VecScale              29 1.0 7.8293e-04 1.0 2.20e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  2809
> VecCopy               14 1.0 7.7058e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecSet               102 1.0 1.4530e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAXPY                9 1.0 3.8154e-04 1.0 9.05e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  2372
> VecAYPX               48 1.0 5.6449e-03 1.0 7.06e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1251
> VecAXPBYCZ            24 1.0 4.0700e-03 1.0 1.41e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  3469
> VecMAXPY              29 1.0 5.1512e-03 1.0 2.04e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  3960
> VecAssemblyBegin       1 1.0 6.7055e-08 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAssemblyEnd         1 1.0 8.1025e-08 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecPointwiseMult      11 1.0 1.8083e-03 1.0 1.29e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   716
> VecSetRandom           1 1.0 1.7628e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecNormalize          29 1.0 1.7100e-03 1.0 6.60e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  3858
> MatMult               58 1.0 5.0949e-02 1.0 8.39e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1647
> MatMultAdd             6 1.0 5.2584e-03 1.0 5.01e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   952
> MatMultTranspose       6 1.0 6.1330e-03 1.0 5.01e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   816
> MatSolve              12 1.0 2.0657e-01 1.0 4.37e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  2  2  0  0  0   2  2  0  0  0  2117
> MatSOR                36 1.0 7.1355e-02 1.0 5.84e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0   818
> MatLUFactorSym         1 1.0 3.4310e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
> MatLUFactorNum         1 1.0 9.8038e+00 1.0 1.69e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 89 96  0  0  0  89 96  0  0  0  1721
> MatConvert             1 1.0 5.6955e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatScale               3 1.0 2.7223e-03 1.0 2.45e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   901
> MatResidual            6 1.0 6.2142e-03 1.0 9.71e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1562
> MatAssemblyBegin      12 1.0 2.7413e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyEnd        12 1.0 2.4857e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetRow         470596 1.0 2.4337e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetRowIJ            1 1.0 2.3254e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetOrdering         1 1.0 1.7668e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatCoarsen             1 1.0 8.5790e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatView                5 1.0 2.2273e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAXPY                1 1.0 1.8864e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMatMult             1 1.0 2.4513e-02 1.0 2.03e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0    83
> MatMatMultSym          1 1.0 1.7885e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMatMultNum          1 1.0 6.6144e-03 1.0 2.03e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   307
> MatPtAP                1 1.0 1.1460e-01 1.0 1.30e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0   114
> MatPtAPSymbolic        1 1.0 4.6803e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatPtAPNumeric         1 1.0 6.7781e-02 1.0 1.30e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0   192
> MatTrnMatMult          1 1.0 9.1702e-02 1.0 1.02e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0   111
> MatTrnMatMultSym       1 1.0 6.0173e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> MatTrnMatMultNum       1 1.0 3.1526e-02 1.0 1.02e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   324
> MatGetSymTrans         2 1.0 4.2753e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> PCGAMGgraph_AGG        1 1.0 6.9175e-02 1.0 1.62e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0    23
> PCGAMGcoarse_AGG       1 1.0 1.1130e-01 1.0 1.02e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0    92
> PCGAMGProl_AGG         1 1.0 2.9380e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> PCGAMGPOpt_AGG         1 1.0 9.1377e-02 1.0 5.15e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0   564
> PCSetUp                2 1.0 1.0587e+01 1.0 1.69e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 96 97  0  0  0  96 97  0  0  0  1601
> PCSetUpOnBlocks        6 1.0 1.0165e+01 1.0 1.69e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 92 96  0  0  0  92 96  0  0  0  1660
> PCApply                6 1.0 1.0503e+01 1.0 1.75e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 95 99  0  0  0  95 99  0  0  0  1662
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150220/70f31cc4/attachment-0001.html>
