[petsc-users] GAMG having very large coarse problem?
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Feb 18 21:48:18 CST 2015
  Mark,
   When I run ksp/ksp/examples/tutorials/ex45 I get a VERY large coarse problem. It seems to ignore the -pc_gamg_coarse_eq_limit 200 argument. Any idea what is going on?
   Thanks
    Barry
$ ./ex45 -da_refine 3 -pc_type gamg -ksp_monitor -ksp_view -log_summary -pc_gamg_coarse_eq_limit 200
  0 KSP Residual norm 2.790769524030e+02
  1 KSP Residual norm 4.484052193577e+01
  2 KSP Residual norm 2.409368790441e+00
  3 KSP Residual norm 1.553421589919e-01
  4 KSP Residual norm 9.821441923699e-03
  5 KSP Residual norm 5.610434857134e-04
KSP Object: 1 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  left preconditioning
  using nonzero initial guess
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: gamg
    MG: type is MULTIPLICATIVE, levels=2 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_coarse_)     1 MPI processes
      type: gmres
      maximum iterations=1, initial guess is zero
      using NONE norm type for convergence test
    PC Object:    (mg_coarse_)     1 MPI processes
      type: bjacobi
        block Jacobi: number of blocks = 1
        Local solve is same for all blocks, in the following KSP and PC objects:
        KSP Object:        (mg_coarse_sub_)         1 MPI processes
          type: preonly
        PC Object:        (mg_coarse_sub_)         1 MPI processes
          type: lu
            LU: out-of-place factorization
            tolerance for zero pivot 2.22045e-14
            using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
            matrix ordering: nd
            factor fill ratio given 5, needed 36.4391
              Factored matrix follows:
                Mat Object:                 1 MPI processes
                  type: seqaij
                  rows=16587, cols=16587
                  package used to perform factorization: petsc
                  total: nonzeros=1.8231e+07, allocated nonzeros=1.8231e+07
                  total number of mallocs used during MatSetValues calls =0
                    not using I-node routines
          linear system matrix = precond matrix:
            type: seqaij
            total: nonzeros=500315, allocated nonzeros=500315
        type: seqaij
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (mg_levels_1_)     1 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.0976343, max = 2.05032
      maximum iterations=2
    PC Object:    (mg_levels_1_)     1 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
        type: seqaij
        rows=117649, cols=117649
        total: nonzeros=809137, allocated nonzeros=809137
  Up solver (post-smoother) same as down solver (pre-smoother)
    type: seqaij
Residual norm 3.81135e-05
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./ex45 on a arch-opt named Barrys-MacBook-Pro.local with 1 processor, by barrysmith Wed Feb 18 21:38:03 2015
Using Petsc Development GIT revision: v3.5.3-1998-geddef31  GIT Date: 2015-02-18 11:05:09 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           1.103e+01      1.00000   1.103e+01
Objects:              9.200e+01      1.00000   9.200e+01
Flops:                1.756e+10      1.00000   1.756e+10  1.756e+10
Flops/sec:            1.592e+09      1.00000   1.592e+09  1.592e+09
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.1030e+01 100.0%  1.7556e+10 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
KSPGMRESOrthog        21 1.0 8.8868e-03 1.0 3.33e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3752
KSPSetUp               5 1.0 4.3986e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 1.0995e+01 1.0 1.76e+10 1.0 0.0e+00 0.0e+00 0.0e+00100100  0  0  0 100100  0  0  0  1596
VecMDot               21 1.0 4.7335e-03 1.0 1.67e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3522
VecNorm               30 1.0 9.4804e-04 1.0 4.63e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4887
VecScale              29 1.0 7.8293e-04 1.0 2.20e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2809
VecCopy               14 1.0 7.7058e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               102 1.0 1.4530e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 3.8154e-04 1.0 9.05e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2372
VecAYPX               48 1.0 5.6449e-03 1.0 7.06e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1251
VecAXPBYCZ            24 1.0 4.0700e-03 1.0 1.41e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3469
VecMAXPY              29 1.0 5.1512e-03 1.0 2.04e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3960
VecAssemblyBegin       1 1.0 6.7055e-08 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         1 1.0 8.1025e-08 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      11 1.0 1.8083e-03 1.0 1.29e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   716
VecSetRandom           1 1.0 1.7628e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          29 1.0 1.7100e-03 1.0 6.60e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3858
MatMult               58 1.0 5.0949e-02 1.0 8.39e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1647
MatMultAdd             6 1.0 5.2584e-03 1.0 5.01e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   952
MatMultTranspose       6 1.0 6.1330e-03 1.0 5.01e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   816
MatSolve              12 1.0 2.0657e-01 1.0 4.37e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2  2  0  0  0   2  2  0  0  0  2117
MatSOR                36 1.0 7.1355e-02 1.0 5.84e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   818
MatLUFactorSym         1 1.0 3.4310e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
MatLUFactorNum         1 1.0 9.8038e+00 1.0 1.69e+10 1.0 0.0e+00 0.0e+00 0.0e+00 89 96  0  0  0  89 96  0  0  0  1721
MatConvert             1 1.0 5.6955e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               3 1.0 2.7223e-03 1.0 2.45e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   901
MatResidual            6 1.0 6.2142e-03 1.0 9.71e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1562
MatAssemblyBegin      12 1.0 2.7413e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        12 1.0 2.4857e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRow         470596 1.0 2.4337e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            1 1.0 2.3254e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 1.7668e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             1 1.0 8.5790e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatView                5 1.0 2.2273e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 1.8864e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMult             1 1.0 2.4513e-02 1.0 2.03e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    83
MatMatMultSym          1 1.0 1.7885e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMultNum          1 1.0 6.6144e-03 1.0 2.03e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   307
MatPtAP                1 1.0 1.1460e-01 1.0 1.30e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   114
MatPtAPSymbolic        1 1.0 4.6803e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatPtAPNumeric         1 1.0 6.7781e-02 1.0 1.30e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   192
MatTrnMatMult          1 1.0 9.1702e-02 1.0 1.02e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   111
MatTrnMatMultSym       1 1.0 6.0173e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatTrnMatMultNum       1 1.0 3.1526e-02 1.0 1.02e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   324
MatGetSymTrans         2 1.0 4.2753e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGgraph_AGG        1 1.0 6.9175e-02 1.0 1.62e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    23
PCGAMGcoarse_AGG       1 1.0 1.1130e-01 1.0 1.02e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    92
PCGAMGProl_AGG         1 1.0 2.9380e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGPOpt_AGG         1 1.0 9.1377e-02 1.0 5.15e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   564
PCSetUp                2 1.0 1.0587e+01 1.0 1.69e+10 1.0 0.0e+00 0.0e+00 0.0e+00 96 97  0  0  0  96 97  0  0  0  1601
PCSetUpOnBlocks        6 1.0 1.0165e+01 1.0 1.69e+10 1.0 0.0e+00 0.0e+00 0.0e+00 92 96  0  0  0  92 96  0  0  0  1660
PCApply                6 1.0 1.0503e+01 1.0 1.75e+10 1.0 0.0e+00 0.0e+00 0.0e+00 95 99  0  0  0  95 99  0  0  0  1662
