[petsc-users] Parallel HDF5 write.
    Ataollah Mesgarnejad
    amesga1 at tigers.lsu.edu
    Thu Feb 19 13:07:09 CST 2015
Dear all,
When I try to write a distributed DMPlex vector using HDF5 I get the
following error:
libpetsc.so.3.5: undefined symbol: H5Pset_fapl_mpio
As far as I understand this is an error due to HDF5 if it is not compiled
in parallel!
I tried both:  PETSc compiled with its own HDF5, and also with a HDF5
compiled on system (stampede). I'm attaching PETSc configure.log as well as
the config.log from external packages HDF5 here (which as far as I can tell
was configured and compiled with --enable-parallel flag).
Many thanks in advance,
Ata
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150219/f5bace29/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150219/f5bace29/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150219/f5bace29/attachment-0003.obj>
