[petsc-users] Question concerning ilu and bcgs
Wed Feb 18 10:57:27 CST 2015
On Wed, Feb 18, 2015 at 10:55 AM, Sun, Hui <hus003 at ucsd.edu> wrote:
>  If I use PETSc's ilu(0), how can I output the matrix L and U?
>  I mean, I can setup pc by PCSetType
> <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCSetType.html#PCSetType>
> (pc,PCLU
> <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCLU.html#PCLU>
> ); And I can output a matrix by MatView. But how do I get the L and the U
> from the pc, so that I can output them?
We do not have output routines for the factors.
     Matt
> Best,
> Hui
> *From:* Sun, Hui
> *Sent:* Wednesday, February 18, 2015 8:47 AM
> *To:* Matthew Knepley
> *Cc:* hong at aspiritech.org; petsc-users at mcs.anl.gov
> *Subject:* RE: [petsc-users] Question concerning ilu and bcgs
>   The matrix is from a 3D fluid problem, with complicated irregular
> boundary conditions. I've tried using direct solvers such as UMFPACK,
> SuperLU_dist and MUMPS. It seems that SuperLU_dist does not solve for my
> linear system; UMFPACK solves the system but would run into memory issue
> even with small size matrices and it cannot parallelize; MUMPS does solve
> the system but it also fails when the size is big and it takes much time.
> That's why I'm seeking an iterative method.
>  I guess the direct method is faster than an iterative method for a small
> A, but that may not be true for bigger A.
> *From:* Matthew Knepley [knepley at gmail.com]
> *Sent:* Wednesday, February 18, 2015 8:33 AM
> *To:* Sun, Hui
> *Subject:* Re: [petsc-users] Question concerning ilu and bcgs
>    On Wed, Feb 18, 2015 at 10:31 AM, Sun, Hui <hus003 at ucsd.edu> wrote:
>>  So far I just try around, I haven't looked into literature yet.
>>  However, both MATLAB's ilu+gmres and ilu+bcgs work. Is it possible that
>> some parameter or options need to be tuned in using PETSc's ilu or hypre's
>> ilu? Besides, is there a way to view how good the performance of the pc is
>> and output the matrices L and U, so that I can do some test in MATLAB?
>  1) Its not clear exactly what Matlab is doing
>  2) PETSc uses ILU(0) by default (you can set it to use ILU(k))
>  3) I don't know what Hypre's ILU can do
>  I would really discourage from using ILU. I cannot imagine it is faster
> than sparse direct factorization
> for your system, such as from SuperLU or MUMPS.
>    Thanks,
>       Matt
>>   Hui
>> *Sent:* Wednesday, February 18, 2015 8:09 AM
>> *To:* Sun, Hui
>>    On Wed, Feb 18, 2015 at 10:02 AM, Sun, Hui <hus003 at ucsd.edu> wrote:
>>>  Yes I've tried other solvers, gmres/ilu does not work, neither does
>>> bcgs/ilu. Here are the options:
>>> -pc_type ilu -pc_factor_nonzeros_along_diagonal -pc_factor_levels 0
>>> -pc_factor_reuse_ordering -ksp_ty\
>>> pe bcgs -ksp_rtol 1e-6 -ksp_max_it 10 -ksp_monitor_short -ksp_view
>>  Note here that ILU(0) is an unreliable and generally crappy
>> preconditioner. Have you looked in the
>> literature for the kinds of preconditioners that are effective for your
>> problem?
>>    Thanks,
>>       Matt
>>>   Here is the output:
>>>   0 KSP Residual norm 211292
>>>   1 KSP Residual norm 13990.2
>>>   2 KSP Residual norm 9870.08
>>>   3 KSP Residual norm 9173.9
>>>   4 KSP Residual norm 9121.94
>>>   5 KSP Residual norm 7386.1
>>>   6 KSP Residual norm 6222.55
>>>   7 KSP Residual norm 7192.94
>>>   8 KSP Residual norm 33964
>>>   9 KSP Residual norm 33960.4
>>>  10 KSP Residual norm 1068.54
>>> KSP Object: 1 MPI processes
>>>   type: bcgs
>>>   maximum iterations=10, initial guess is zero
>>>   tolerances:  relative=1e-06, absolute=1e-50, divergence=10000
>>>   left preconditioning
>>>   using PRECONDITIONED norm type for convergence test
>>> PC Object: 1 MPI processes
>>>   type: ilu
>>>     ILU: out-of-place factorization
>>>     ILU: Reusing reordering from past factorization
>>>     0 levels of fill
>>>     tolerance for zero pivot 2.22045e-14
>>>     using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>>>     matrix ordering: natural
>>>     factor fill ratio given 1, needed 1
>>>       Factored matrix follows:
>>>         Mat Object:         1 MPI processes
>>>           type: seqaij
>>>           rows=62500, cols=62500
>>>           package used to perform factorization: petsc
>>>           total: nonzeros=473355, allocated nonzeros=473355
>>>           total number of mallocs used during MatSetValues calls =0
>>>             not using I-node routines
>>>   linear system matrix = precond matrix:
>>>     type: seqaij
>>>     total: nonzeros=473355, allocated nonzeros=7.8125e+06
>>> Time cost: 0.307149,  0.268402,  0.0990018
>>> *From:* hong at aspiritech.org [hong at aspiritech.org]
>>> *Sent:* Wednesday, February 18, 2015 7:49 AM
>>> *To:* Sun, Hui
>>> *Cc:* Matthew Knepley; petsc-users at mcs.anl.gov
>>>    Have you tried other solvers, e.g., PETSc default gmres/ilu,
>>> bcgs/ilu etc.
>>> The matrix is small. If it is ill-conditioned, then pc_type lu would
>>> work the best.
>>>  Hong
>>> On Wed, Feb 18, 2015 at 9:34 AM, Sun, Hui <hus003 at ucsd.edu> wrote:
>>>>  With options:
>>>>  -pc_type hypre -pc_hypre_type pilut -pc_hypre_pilut_maxiter 1000
>>>> -pc_hypre_pilut_tol 1e-3 -ksp_type bcgs -ksp_rtol 1e-10 -ksp_max_it 10
>>>> -ksp_monitor_short -ksp_converged_reason -ksp_view
>>>>  Here is the full output:
>>>>    0 KSP Residual norm 1404.62
>>>>   1 KSP Residual norm 88.9068
>>>>   2 KSP Residual norm 64.73
>>>>   3 KSP Residual norm 71.0224
>>>>   4 KSP Residual norm 69.5044
>>>>   5 KSP Residual norm 455.458
>>>>   6 KSP Residual norm 174.876
>>>>   7 KSP Residual norm 183.031
>>>>   8 KSP Residual norm 650.675
>>>>   9 KSP Residual norm 79.2441
>>>>  10 KSP Residual norm 84.1985
>>>> Linear solve did not converge due to DIVERGED_ITS iterations 10
>>>>   type: bcgs
>>>>   tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
>>>>   type: hypre
>>>>     HYPRE Pilut preconditioning
>>>>     HYPRE Pilut: maximum number of iterations 1000
>>>>     HYPRE Pilut: drop tolerance 0.001
>>>>     HYPRE Pilut: default factor row size
>>>>     type: seqaij
>>>> Time cost: 0.756198,  0.662984,  0.105672
>>>> *Sent:* Wednesday, February 18, 2015 3:30 AM
>>>> *To:* Sun, Hui
>>>> *Cc:* petsc-users at mcs.anl.gov
>>>>     On Wed, Feb 18, 2015 at 12:33 AM, Sun, Hui <hus003 at ucsd.edu> wrote:
>>>>>  I have a matrix system Ax = b, A is of type MatSeqAIJ or MatMPIAIJ,
>>>>> depending on the number of cores.
>>>>>  I try to solve this problem by pc_type ilu and ksp_type bcgs, it
>>>>> does not converge. The options I specify are:
>>>>> -pc_hypre_pilut_tol 1e-3 -ksp_type b\
>>>>> cgs -ksp_rtol 1e-10 -ksp_max_it 1000 -ksp_monitor_short
>>>>  1) Run with -ksp_view, so we can see exactly what was used
>>>>  2) ILUT is unfortunately not a well-defined algorithm, and I believe
>>>> the parallel version makes different decisions
>>>>     than the serial version.
>>>>    Thanks,
>>>>      Matt
>>>>>   The first a few lines of the output are:
>>>>>  This clearly indicates non-convergence. However, I output the sparse
>>>>> matrix A and vector b to MATLAB, and run the following command:
>>>>> [L,U] = ilu(A,struct('type','ilutp','droptol',1e-3));
>>>>> [ux1,fl1,rr1,it1,rv1] = bicgstab(A,b,1e-10,1000,L,U);
>>>>>  And it converges in MATLAB, with flag fl1=0, relative residue
>>>>> rr1=8.2725e-11, and iteration it1=89.5. I'm wondering how can I figure out
>>>>> what's wrong.
>>>>>  Best,
>>>>> Hui
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150218/60e1a015/attachment-0001.html>
