[petsc-users] SGI compiler (mpt-2.11) and fortran interface
    Matthew Knepley
    knepley at gmail.com
    Wed Feb 11 11:38:58 CST 2015
On Wed, Feb 11, 2015 at 11:35 AM, Matteo Parsani <parsani.matteo at gmail.com>
wrote:
> I forgot to say that I am using PETSc 3.5
How are you declaring xx_v?
  Matt
> On Wed, Feb 11, 2015 at 12:32 PM, Matteo Parsani <parsani.matteo at gmail.com
> > wrote:
>> Dear Petsc Users and Developers,
>> Recently, I have compiled my fortran code using the SGI compiler
>> (mpt-2.11). Previously I was using openmpi 1.7.3 and everything worked fine.
>> Now, with when I run the code compiled with SGI I get the following error:
>> At line 1921 of file mpi_module.F90
>> Fortran runtime error: Array reference out of bounds for array 'xx_v',
>> upper bound of dimension 1 exceeded (349921 > 1)
>> Precisely the line that gives troubles is the following
>> x_ghost(i_dir,i_loc) = xx_v(n_tot+3*(i_loc-1) + i_dir)
>> The variables xx_v is a fortran pointer which I get using
>> call VecGetArrayF90(x_local, xx_v, i_er)
>> where i_err is defined as
>> PetscErrorCode i_err
>> Do you have any idea what I am doing wrong?
>> Thank you!
>> Matteo
> Matteo
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150211/8449e2e3/attachment.html>
