[petsc-users] SGI compiler (mpt-2.11) and fortran interface
    Matthew Knepley
    knepley at gmail.com
    Wed Feb 11 11:42:27 CST 2015
On Wed, Feb 11, 2015 at 11:41 AM, Matteo Parsani <parsani.matteo at gmail.com>
wrote:
> Should I use
> PetscScalar, pointer, dimension(:) :: xx_v
Yes, but I am not sure that will solve your problem. Do the PETSc F90
examples run with this compiler?
  Matt
> On Wed, Feb 11, 2015 at 12:39 PM, Matteo Parsani <parsani.matteo at gmail.com
> > wrote:
>> In this way:
>> real(wp), pointer, dimension(:) :: xx_v
>> where wp is my working precision
>> On Wed, Feb 11, 2015 at 12:38 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Wed, Feb 11, 2015 at 11:35 AM, Matteo Parsani <
>>> parsani.matteo at gmail.com> wrote:
>>>> I forgot to say that I am using PETSc 3.5
>>> How are you declaring xx_v?
>>>   Matt
>>>> On Wed, Feb 11, 2015 at 12:32 PM, Matteo Parsani <
>>>>> Dear Petsc Users and Developers,
>>>>> Recently, I have compiled my fortran code using the SGI compiler
>>>>> (mpt-2.11). Previously I was using openmpi 1.7.3 and everything worked fine.
>>>>> Now, with when I run the code compiled with SGI I get the following
>>>>> error:
>>>>> At line 1921 of file mpi_module.F90
>>>>> Fortran runtime error: Array reference out of bounds for array 'xx_v',
>>>>> upper bound of dimension 1 exceeded (349921 > 1)
>>>>> Precisely the line that gives troubles is the following
>>>>> x_ghost(i_dir,i_loc) = xx_v(n_tot+3*(i_loc-1) + i_dir)
>>>>> The variables xx_v is a fortran pointer which I get using
>>>>> call VecGetArrayF90(x_local, xx_v, i_er)
>>>>> where i_err is defined as
>>>>> PetscErrorCode i_err
>>>>> Do you have any idea what I am doing wrong?
>>>>> Thank you!
>>>>> Matteo
>>>> Matteo
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> Matteo
> Matteo
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150211/5bf461fe/attachment-0001.html>
