[petsc-users] SGI compiler (mpt-2.11) and fortran interface
Matteo Parsani
parsani.matteo at gmail.com
Wed Feb 11 11:35:46 CST 2015
I forgot to say that I am using PETSc 3.5
On Wed, Feb 11, 2015 at 12:32 PM, Matteo Parsani <parsani.matteo at gmail.com>
wrote:
> Dear Petsc Users and Developers,
> Recently, I have compiled my fortran code using the SGI compiler
> (mpt-2.11). Previously I was using openmpi 1.7.3 and everything worked fine.
> Now, with when I run the code compiled with SGI I get the following error:
> At line 1921 of file mpi_module.F90
> Fortran runtime error: Array reference out of bounds for array 'xx_v',
> upper bound of dimension 1 exceeded (349921 > 1)
> Precisely the line that gives troubles is the following
> x_ghost(i_dir,i_loc) = xx_v(n_tot+3*(i_loc-1) + i_dir)
> The variables xx_v is a fortran pointer which I get using
> call VecGetArrayF90(x_local, xx_v, i_er)
> where i_err is defined as
> PetscErrorCode i_err
> Do you have any idea what I am doing wrong?
> Thank you!
> Matteo
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150211/3ba083f7/attachment.html>
