[petsc-users] Full blas-lapack on Windows
Satish Balay
balay at mcs.anl.gov
Mon Feb 9 10:47:27 CST 2015
I think we had this conversation before.
--download-f2cblaslapack will give you a full blas/lapack.
And you can't use MUMPS without a fortran compiler [as far as I know]
You should be able to use superlu_dist
Satish
On Mon, 9 Feb 2015, Fabien RAPHEL wrote:
> Hello,
> I can configure, compile and use PETSc on Windows with Visual Studio 2008
> (in serial and parallel).
> But I would like to use a LU factorization in parallel (for example, using
> Superlu_dist or MUMPS library).
> I don't have FORTRAN compiler on my machine, so I can't compile the full
> version of BLAS/LAPACK (with the slamch() routine for example).
> I found a precompiled version of the full libraries (I can run an sample
> in VS2008).
> But I have a PETSc configure error: "--with-blas-lapack-lib..... cannot be
> used" and the configure.log returns a lot of undefined references whereas
> I set the libraries and the include file during configuration.
> Do I forgot something in the command line? Or is the error comes from the
> library?
> Or, is there a C/C++ library who can do that?
> Thanks in advance,
> Fabien
