[petsc-users] Mapping between application ordering and Petsc ordering
Mani Chandra
mc0710 at gmail.com
Sat Aug 8 14:45:45 CDT 2015
Thanks. Any suggestions for a fix?
Reorder the indices in arrayApplication?
On Sat, Aug 8, 2015 at 2:19 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Aug 8, 2015 at 1:52 PM, Mani Chandra <mc0710 at gmail.com> wrote:
>> Hi,
>> I'm having trouble interfacing petsc to an application which I think is
>> related to the ordering of the nodes. Here's what I'm trying to do:
>> The application uses a structured grid with a global array having
>> dimensions N1 x N2, which is then decomposed into a local array with
>> dimensions NX1 x NX2.
>> I create a Petsc DMDA using
>> DMDACreate2d(MPI_COMM_WORLD,
>> DM_BOUNDARY_PERIODIC, DM_BOUNDARY_PERIODIC,
>> DMDA_STENCIL_BOX,
>> N1, N2,
>> N1/NX1, N2/NX2,
>> 1, nghost, PETSC_NULL, PETSC_NULL,
>> &dmda);
>> and then use this to create a vec:
>> DMCreateGlobalVector(dmda, &vec);
>> Now I copy the local contents of the application array to the petsc array
>> using the following:
>> Let i, j be the application indices and iPetsc and jPetsc be petsc's
>> indices, then:
>> DMDAGetCorners(dmda, &iStart, &jStart, &kStart,
>> &iSize, &jSize, &kSize
>> double **arrayPetsc;
>> DMDAVecGetArray(dmda, vec, &arrayPetsc);
>> for (int j=0, jPetsc=jStart; j<NX2, jPetsc<jStart+jSize; j++, jPetsc++)
>> for (int i=0, iPetsc=iStart; i<NX1, iPetsc<iStart+iSize; i++, iPetsc++)
>> arrayPetsc[jPetsc][iPetsc] = arrayApplication[j][i];
>> DMDAVecRestoreArray(dmda, vec, &arrayPetsc);
>> Now if I VecView(vec, viewer) and look at the data that petsc has, it
>> looks right when run with 1 proc, but if I use 4 procs it's all messed up
>> (see attached plots).
>> I should probably be using the AO object but its not clear how. Could you
>> help me out?
> It looks like you have the global order of processes reversed, meaning you
> have
> 1 3
> 0 2
> and it should be
> 2 3
> 0 1
> Thanks,
> Matt
>> Thanks,
>> Mani
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150808/4216b6f5/attachment.html>
