[petsc-users] Mapping between application ordering and Petsc	ordering
    Matthew Knepley
    knepley at gmail.com
    Sat Aug  8 14:48:43 CDT 2015
On Sat, Aug 8, 2015 at 2:45 PM, Mani Chandra <mc0710 at gmail.com> wrote:
> Thanks. Any suggestions for a fix?
You have to deal with the right part of the domain in your application
code. I have no idea
how you are handling this, and its not in the code below.
   Matt
> Reorder the indices in arrayApplication?
> On Sat, Aug 8, 2015 at 2:19 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sat, Aug 8, 2015 at 1:52 PM, Mani Chandra <mc0710 at gmail.com> wrote:
>>> Hi,
>>> I'm having trouble interfacing petsc to an application which I think is
>>> related to the ordering of the nodes. Here's what I'm trying to do:
>>> The application uses a structured grid with a global array having
>>> dimensions N1 x N2, which is then decomposed into a local array with
>>> dimensions NX1 x NX2.
>>> I create a Petsc DMDA using
>>>     DMDACreate2d(MPI_COMM_WORLD,
>>>                  DM_BOUNDARY_PERIODIC, DM_BOUNDARY_PERIODIC,
>>>                  DMDA_STENCIL_BOX,
>>>                  N1, N2,
>>>                  N1/NX1, N2/NX2,
>>>                  1, nghost, PETSC_NULL, PETSC_NULL,
>>>                  &dmda);
>>> and then use this to create a vec:
>>>   DMCreateGlobalVector(dmda, &vec);
>>> Now I copy the local contents of the application array to the petsc
>>> array using the following:
>>> Let i, j be the application indices and iPetsc and jPetsc be petsc's
>>> indices, then:
>>> DMDAGetCorners(dmda, &iStart, &jStart, &kStart,
>>>                                          &iSize, &jSize, &kSize
>>> double **arrayPetsc;
>>> DMDAVecGetArray(dmda, vec, &arrayPetsc);
>>> for (int j=0, jPetsc=jStart; j<NX2, jPetsc<jStart+jSize; j++, jPetsc++)
>>>   for (int i=0, iPetsc=iStart; i<NX1, iPetsc<iStart+iSize; i++, iPetsc++)
>>>      arrayPetsc[jPetsc][iPetsc] = arrayApplication[j][i];
>>> DMDAVecRestoreArray(dmda, vec, &arrayPetsc);
>>> Now if I VecView(vec, viewer) and look at the data that petsc has, it
>>> looks right when run with 1 proc, but if I use 4 procs it's all messed up
>>> (see attached plots).
>>> I should probably be using the AO object but its not clear how. Could
>>> you help me out?
>> It looks like you have the global order of processes reversed, meaning
>> you have
>>   1   3
>>   0   2
>> and it should be
>>   2  3
>>   0  1
>>   Thanks,
>>       Matt
>>> Thanks,
>>> Mani
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150808/bdfa3dcb/attachment.html>
