[petsc-users] reg: Eigenvectors of general complex eigen value problem
venkatesh g venkateshgk.j at gmail.com
Mon Mar 24 05:45:35 CDT 2014
Thanks a lot. I did what you told.
It is working now like a charm.
However, I have another query, which I will post separately.
On Mon, Mar 24, 2014 at 3:21 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 24/03/2014, a las 10:28, venkatesh g escribió:
> > Ok. I am doing the following
> > 1. Running "./ex7 -f1 A2 -f2 B2 -st_type sinvert -evecs VC"
> > 2. In MATLAB I do "vc=PetscBinaryRead('VC');"
> > The output is one Eigenvector in VC which is 800x1.
> > And I did the normalization vc=vc/max(vc) and compared with the
> normalized original vector.. Also I must tell that if A2 and B2 are real,
> it works.
> > I also changed the line 179 of ex7.c like u said.
> > Pls let me know.
> You should do
>   vc=PetscBinaryRead('VC','complex',true);
> If you want to load several eigenvectors, then
>   vc=PetscBinaryRead('VC','complex',true,'cell',nconv);
> where nconv is the number of converged eigenpairs reported by SLEPc. In
> that case, the result is a cell array so vc{1} is the first eigenvector,
> vc{2} the second one, and so on.
> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140324/597e4c21/attachment.html>
