[petsc-users] vtk output ASCII or binary
Xiangdong
epscodes at gmail.com
Wed Mar 5 14:25:24 CST 2014
On Wed, Mar 5, 2014 at 2:21 PM, Jed Brown <jed at jedbrown.org> wrote:
> Xiangdong <epscodes at gmail.com> writes:
> > I got the following error messages on each processor when use mpiio:
> > [5]PETSC ERROR: DMDAArrayMPIIO() line 532 in
> > MyLocal/petsc/petsc-3.4.3/src/dm/impls/da/gr2.c
> Looks like this line is failing. Please either use a debugger or create
> a representative test case so we can debug.
> ierr =
> MPI_Type_create_subarray(dd->dim+1,gsizes,lsizes,lstarts,MPI_ORDER_FORTRAN,MPIU_SCALAR,&view);CHKERRQ(ierr);
> Does this work?
> petsc/src/ksp/ksp/examples/tutorials$ mpiexec -n 4 ./ex45 -da_refine 3
> -ksp_monitor -pc_type mg -ksp_view_solution binary:foo -viewer_binary_mpiio
This works fine. However, when I add the option -da_grid_x 8, the same
error messages pop up.
It is strange that -da_grid_x 5 works fine. Moreover, if we set M=N=P=8, it
also works fine.
Thank you.
Xiangdong
> > [5]PETSC ERROR: VecView_MPI_DA() line 605 in
> > [5]PETSC ERROR: VecView() line 717 in
> > MyLocal/petsc/petsc-3.4.3/src/vec/vec/interface/vector.c
> > The program does not crash, but skip writing the binary output.
> That's because you weren't checking error codes.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140305/d92e4267/attachment-0001.html>
