[petsc-users] vtk output ASCII or binary
Jed Brown jed at jedbrown.org
Wed Mar 5 13:21:54 CST 2014
Xiangdong <epscodes at gmail.com> writes:
> I got the following error messages on each processor when use mpiio:
> [5]PETSC ERROR: DMDAArrayMPIIO() line 532 in
> MyLocal/petsc/petsc-3.4.3/src/dm/impls/da/gr2.c
Looks like this line is failing.  Please either use a debugger or create
a representative test case so we can debug.
  ierr       = MPI_Type_create_subarray(dd->dim+1,gsizes,lsizes,lstarts,MPI_ORDER_FORTRAN,MPIU_SCALAR,&view);CHKERRQ(ierr);
Does this work?
petsc/src/ksp/ksp/examples/tutorials$ mpiexec -n 4 ./ex45 -da_refine 3 -ksp_monitor -pc_type mg -ksp_view_solution binary:foo -viewer_binary_mpiio
> [5]PETSC ERROR: VecView_MPI_DA() line 605 in
> [5]PETSC ERROR: VecView() line 717 in
> MyLocal/petsc/petsc-3.4.3/src/vec/vec/interface/vector.c
> The program does not crash, but skip writing the binary output.
That's because you weren't checking error codes.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140305/cf7de890/attachment.pgp>
