[petsc-users] vtk output ASCII or binary
Jed Brown
jed at jedbrown.org
Thu Mar 6 18:38:57 CST 2014
Xiangdong <epscodes at gmail.com> writes:
> This works fine. However, when I add the option -da_grid_x 8, the same
> error messages pop up.
There was a memory error introduced when Barry changed PetscMPIIntCast
to be better behaved. For equal-aspect grids, the uninitialized slot
contained the right value by accident. Thanks.
If you are using PETSc from Git, run "git pull && make", otherwise you
can apply the patch below and rebuild.
commit 334634e2e3b3ad30f394a243f8d8200a86444220
Author: Jed Brown <jed at jedbrown.org>
Date: Thu Mar 6 17:28:37 2014 -0700
VecView_MPI_DA: fix gsizes bug (bad conversion in parent commit)
Reported-by: Xiangdong <epscodes at gmail.com>
diff --git a/src/dm/impls/da/gr2.c b/src/dm/impls/da/gr2.c
index f726037..abb8dea 100644
--- a/src/dm/impls/da/gr2.c
+++ b/src/dm/impls/da/gr2.c
@@ -472,7 +472,7 @@ static PetscErrorCode DMDAArrayMPIIO(DM da,PetscViewer viewer,Vec xin,PetscBool
gsizes[0] = dof;
ierr = PetscMPIIntCast(dd->M,gsizes+1);CHKERRQ(ierr);
ierr = PetscMPIIntCast(dd->N,gsizes+2);CHKERRQ(ierr);
- ierr = PetscMPIIntCast(dd->P,gsizes+1);CHKERRQ(ierr);
+ ierr = PetscMPIIntCast(dd->P,gsizes+3);CHKERRQ(ierr);
lsizes[0] = dof;
ierr = PetscMPIIntCast((dd->xe-dd->xs)/dof,lsizes+1);CHKERRQ(ierr);
ierr = PetscMPIIntCast(dd->ye-dd->ys,lsizes+2);CHKERRQ(ierr);
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140306/0b8a42ae/attachment.pgp>
