[petsc-users] vtk output ASCII or binary
Xiangdong
epscodes at gmail.com
Wed Mar 5 13:12:52 CST 2014
I got the following error messages on each processor when use mpiio:
[5]PETSC ERROR: DMDAArrayMPIIO() line 532 in
MyLocal/petsc/petsc-3.4.3/src/dm/impls/da/gr2.c
[5]PETSC ERROR: VecView_MPI_DA() line 605 in
[5]PETSC ERROR: VecView() line 717 in
MyLocal/petsc/petsc-3.4.3/src/vec/vec/interface/vector.c
The program does not crash, but skip writing the binary output.
Thank you.
Xiangdong
On Wed, Mar 5, 2014 at 1:47 PM, Jed Brown <jed at jedbrown.org> wrote:
> Xiangdong <epscodes at gmail.com> writes:
> > When using the option -viewer_binary_mpiio, I see PETSC Error:
> > DMDAArrayMPIIO() line 532 in /src/dm/impls/da/gr2.c.
> NEVER truncate an error message. (We have to remind people of this
> every day. Always send the whole thing.)
> MPI-IO works for me and in our tests, so we should figure out what
> happened.
> > However, when I run it without mpiio, it outputs the binary data fine.
> What
> > options am I missing here?
> Time it so we can compare output performance using the different methods.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140305/28fe2e1c/attachment-0001.html>
