[petsc-users] vtk output ASCII or binary
Xiangdong
epscodes at gmail.com
Tue Mar 4 19:28:30 CST 2014
At this moment, when I write the solutions (two vectors with a few billion
unknowns) to binary vts format, the writing rate is about 100MB/s from proc
0.
Do you think writing the data into pvts format will enhance the
performance? Can I use some PETSc functions to save the local vector as
pvts format and view them as a global vector through paraview/visit?
Thank you.
Xiangdong
On Tue, Mar 4, 2014 at 4:49 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Mar 4, 2014 at 3:43 PM, Xiangdong <epscodes at gmail.com> wrote:
>> If I use VecView and write the vector into vtk file, is this done in
>> parallel or serial? Does each processor send the data to processor 0 and
>> let it write to the disk?
>> Is it possible to let each processor write its own portion and merge them
>> together later?
> I urge you strongly to avoid premature optimization and worrying.
> If you want to discuss details that is fine, but I do not think the fears
> expressed
> above are grounded in reality. Network bandwidth is at least as good as
> memory
> bandwidth, so sending to proc 0 is not a problem below 10,000 procs or so.
> You
> might think serializing the disk writes would be, but its very likely your
> machine
> is doing that anyway by having a small number (usually 1) of I/O nodes.
> For high
> core counts we can use MPI I/O which you can turn on with a command line
> argument.
> Matt
>> Thank you.
>> Xiangdong
>> On Tue, Mar 4, 2014 at 2:06 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Tue, Mar 4, 2014 at 12:58 PM, Xiangdong <epscodes at gmail.com> wrote:
>>>> Thanks, Matt.
>>>> Given that the FILE_MODE_APPEND is not supported for VTK format, is it
>>>> possible to write two vectors into the same VTK data file?
>>> Yes, just call VecView() twice.
>>> Matt
>>>> Thank you.
>>>> Xiangdong
>>>> On Tue, Mar 4, 2014 at 1:52 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Tue, Mar 4, 2014 at 12:31 PM, Xiangdong <epscodes at gmail.com> wrote:
>>>>>> What is the difference between PetscViewerSetType and
>>>>>> PetscViewerSetFormat? It seems that the first one take argument like
>>>>>> PETSCVIEWERVTK, while the second one takes PETSC_VIEWER_VTK_VTS.
>>>>> A viewer type is the object type, just like other PETSc object, e.g.
>>>>> KSP. The format is a particular version
>>>>> of that output. For example, ASCII viewer is a type, whereas Matlab is
>>>>> a format.
>>>>>> By the way, how can I find a full list of formats? Clearly,
>>>>>> PETSC_VIEWER_VTK_VTS is not listed in online documentation for
>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerSetFormat.html
>>>>> It is listed in the complete list:
>>>>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Viewer/PetscViewerFormat.html
>>>>> Matt
>>>>>> Thank you.
>>>>>> Xiangdong
>>>>>> On Tue, Mar 4, 2014 at 1:02 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Tue, Mar 4, 2014 at 11:44 AM, Xiangdong <epscodes at gmail.com>wrote:
>>>>>>>> Hello everyone,
>>>>>>>> When I use PetsViewerVTKOpen to output vec in vtk format, is it in
>>>>>>>> ASCII format or binary format? Are there any options to choose between them?
>>>>>>> It is determined by the format, e.g. PETSC_VIEWER_VTK_VTU.
>>>>>>> Matt
>>>>>>>> Thank you.
>>>>>>>> Xiangdong
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140304/00f1a8d9/attachment.html>
