[petsc-users] vtk output ASCII or binary
Tue Mar 4 15:49:24 CST 2014
On Tue, Mar 4, 2014 at 3:43 PM, Xiangdong <epscodes at gmail.com> wrote:
> If I use VecView and write the vector into vtk file, is this done in
> parallel or serial? Does  each processor send the data to processor 0 and
> let it write to the disk?
> Is it possible to let each processor write its own portion and merge them
> together later?
I urge you strongly to avoid premature optimization and worrying.
If you want to discuss details that is fine, but I do not think the fears
expressed
above are grounded in reality. Network bandwidth is at least as good as
memory
bandwidth, so sending to proc 0 is not a problem below 10,000 procs or so.
You
might think serializing the disk writes would be, but its very likely your
machine
is doing that anyway by having a small number (usually 1) of I/O nodes. For
high
core counts we can use MPI I/O which you can turn on with a command line
argument.
   Matt
> Thank you.
> Xiangdong
> On Tue, Mar 4, 2014 at 2:06 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Mar 4, 2014 at 12:58 PM, Xiangdong <epscodes at gmail.com> wrote:
>>> Thanks, Matt.
>>> Given that the FILE_MODE_APPEND is not supported for VTK format, is it
>>> possible to write two vectors into the same VTK data file?
>> Yes, just call VecView() twice.
>>    Matt
>>> Thank you.
>>> Xiangdong
>>> On Tue, Mar 4, 2014 at 1:52 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Tue, Mar 4, 2014 at 12:31 PM, Xiangdong <epscodes at gmail.com> wrote:
>>>>> What is the difference between PetscViewerSetType and
>>>>> PetscViewerSetFormat? It seems that the first one take argument like
>>>>> PETSCVIEWERVTK, while the second one takes PETSC_VIEWER_VTK_VTS.
>>>> A viewer type is the object type, just like other PETSc object, e.g.
>>>> KSP. The format is a particular version
>>>> of that output. For example, ASCII viewer is a type, whereas Matlab is
>>>> a format.
>>>>> By the way, how can I find a full list of formats? Clearly,
>>>>> PETSC_VIEWER_VTK_VTS is not listed in online documentation for
>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerSetFormat.html
>>>> It is listed in the complete list:
>>>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Viewer/PetscViewerFormat.html
>>>>     Matt
>>>>>  Thank you.
>>>>> Xiangdong
>>>>> On Tue, Mar 4, 2014 at 1:02 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Tue, Mar 4, 2014 at 11:44 AM, Xiangdong <epscodes at gmail.com>wrote:
>>>>>>> Hello everyone,
>>>>>>> When I use PetsViewerVTKOpen to output vec in vtk format, is it in
>>>>>>> ASCII format or binary format? Are there any options to choose between them?
>>>>>> It is determined by the format, e.g. PETSC_VIEWER_VTK_VTU.
>>>>>>    Matt
>>>>>>> Thank you.
>>>>>>> Xiangdong
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140304/cd4725dd/attachment-0001.html>
