[petsc-users] vtk output ASCII or binary
Xiangdong
epscodes at gmail.com
Tue Mar 4 12:58:09 CST 2014
Thanks, Matt.
Given that the FILE_MODE_APPEND is not supported for VTK format, is it
possible to write two vectors into the same VTK data file?
Thank you.
Xiangdong
On Tue, Mar 4, 2014 at 1:52 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Mar 4, 2014 at 12:31 PM, Xiangdong <epscodes at gmail.com> wrote:
>> What is the difference between PetscViewerSetType and
>> PetscViewerSetFormat? It seems that the first one take argument like
>> PETSCVIEWERVTK, while the second one takes PETSC_VIEWER_VTK_VTS.
> A viewer type is the object type, just like other PETSc object, e.g. KSP.
> The format is a particular version
> of that output. For example, ASCII viewer is a type, whereas Matlab is a
> format.
>> By the way, how can I find a full list of formats? Clearly,
>> PETSC_VIEWER_VTK_VTS is not listed in online documentation for
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerSetFormat.html
> It is listed in the complete list:
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Viewer/PetscViewerFormat.html
> Matt
>> Thank you.
>> Xiangdong
>> On Tue, Mar 4, 2014 at 1:02 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Tue, Mar 4, 2014 at 11:44 AM, Xiangdong <epscodes at gmail.com> wrote:
>>>> Hello everyone,
>>>> When I use PetsViewerVTKOpen to output vec in vtk format, is it in
>>>> ASCII format or binary format? Are there any options to choose between them?
>>> It is determined by the format, e.g. PETSC_VIEWER_VTK_VTU.
>>> Matt
>>>> Thank you.
>>>> Xiangdong
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140304/5d12a09b/attachment-0001.html>
