[petsc-users] vtk output ASCII or binary
Tue Mar 4 13:06:15 CST 2014
On Tue, Mar 4, 2014 at 12:58 PM, Xiangdong <epscodes at gmail.com> wrote:
> Thanks, Matt.
> Given that the FILE_MODE_APPEND is not supported for VTK format, is it
> possible to write two vectors into the same VTK data file?
Yes, just call VecView() twice.
   Matt
> Thank you.
> Xiangdong
> On Tue, Mar 4, 2014 at 1:52 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Mar 4, 2014 at 12:31 PM, Xiangdong <epscodes at gmail.com> wrote:
>>> What is the difference between PetscViewerSetType and
>>> PetscViewerSetFormat? It seems that the first one take argument like
>>> PETSCVIEWERVTK, while the second one takes PETSC_VIEWER_VTK_VTS.
>> A viewer type is the object type, just like other PETSc object, e.g. KSP.
>> The format is a particular version
>> of that output. For example, ASCII viewer is a type, whereas Matlab is a
>> format.
>>> By the way, how can I find a full list of formats? Clearly,
>>> PETSC_VIEWER_VTK_VTS is not listed in online documentation for
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerSetFormat.html
>> It is listed in the complete list:
>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Viewer/PetscViewerFormat.html
>>     Matt
>>>  Thank you.
>>> Xiangdong
>>> On Tue, Mar 4, 2014 at 1:02 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Tue, Mar 4, 2014 at 11:44 AM, Xiangdong <epscodes at gmail.com> wrote:
>>>>> Hello everyone,
>>>>> When I use PetsViewerVTKOpen to output vec in vtk format, is it in
>>>>> ASCII format or binary format? Are there any options to choose between them?
>>>> It is determined by the format, e.g. PETSC_VIEWER_VTK_VTU.
>>>>    Matt
>>>>> Thank you.
>>>>> Xiangdong
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140304/8dc09dfe/attachment.html>
