[petsc-users] Any examples to output a dmplex mesh as a hdf5 file?
Matthew Knepley
knepley at gmail.com
Thu Jun 26 23:31:51 CDT 2014
On Thu, Jun 26, 2014 at 6:52 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
> Hi Matt,
> Is it possible to send me some printed hdf5 and xdmf files (representing
> a simple mesh) that can be visualized by Paraview? Similarly like that
> printed by pylith. From these files I think I can figure out how to write a
> hdf5 viewer by myself.
I can, here is a representative HDF5 file (you can generate Xdmf using
bin/pythonscripts/petsc_gen_xdmf.py). Did the
viewer not work for you?
Matt
> Sorry for bothering you.
> Thanks,
> On Wed, Jun 25, 2014 at 11:46 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Jun 24, 2014 at 7:50 AM, Fande Kong <fd.kong at siat.ac.cn> wrote:
>>> Hi all,
>>> There are some functions called DMPlex_load_hdf5 and DMPlex_view_hdf5 in
>>> petsc-dev. They are really good functions for outputting the solution as a
>>> hdf5 file in parallel. Are there any examples to show how to use these
>>> functions? Or are there some printed hdf5 and xdmf files that can be
>>> visualized by paraview?
>> This is very new code. I plan to write a manual section as soon as the
>> functionality solidifies. However, here is how I am currently using it.
>> Anywhere that you think about viewing something add
>> ierr = PetscObjectViewFromOptions((PetscObject) obj, prefix,
>> "-my_obj_view");CHKERRQ(ierr);
>> Then you can use the standard option style
>> -my_obj_view hdf5:my.h5
>> This extends nicely to many objects. Here is what I use for my magma
>> dynamics output
>> -dm_view hdf5:sol_solver_debug.h5 -magma_view_solution
>> hdf5:sol_solver_debug.h5::append -compaction_vec_view
>> hdf5:sol_solver_debug.h5:HDF5_VIZ:append
>> There is still a problem in that you cannot choose multiple formats using
>> this method. I am going to extend
>> the view options format
>> type:file:format:mode
>> to allow
>> type:file:format,format,format:mode
>> to handle this.
>> Thanks,
>> Matt
>>> Thanks,
>>> Fande,
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140626/c7f1bfb9/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140626/c7f1bfb9/attachment-0001.obj>
