[petsc-users] Viewing DM Vector stored on Multiple GPUs
Ashwin Srinath
ashwinsrnth at gmail.com
Tue Jun 24 21:15:49 CDT 2014
Hello, petsc-users
I'm having trouble *viewing* an mpicusp vector. Here's the simplest case
that reproduces the problem:
int main(int argc, char** argv) {
PetscInitialize(&argc, &argv, NULL, NULL);
DM da;
Vec V;
DMDACreate2d( PETSC_COMM_WORLD,
DM_BOUNDARY_NONE, DM_BOUNDARY_NONE,
DMDA_STENCIL_BOX,
5, 5,
PETSC_DECIDE, PETSC_DECIDE,
1,
1,
NULL, NULL,
&da);
DMCreateGlobalVector(da, &V);
VecSet(V, 1);
VecView(V, PETSC_VIEWER_STDOUT_WORLD);
PetscFinalize();
return 0;
I get the error:
[1]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Trying to copy from a null pointer
I executed with the following command:
mpiexec -n 2 ./main -dm_vec_type cusp -vec_type cusp
Both GPUs are attached to two different processes.
This program works fine for vecmpi vectors, i.e., -dm_vec_type mpi and
-vec_type mpi. Also, I don't get an error unless I try to *view* the
vector. Can someone please point out what I'm doing wrong?
Thanks for your time,
Ashwin Srinath
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140624/685c3dc1/attachment.html>
