[petsc-users] SNES divergence
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Jun 17 14:20:42 CDT 2014
On Jun 17, 2014, at 2:12 PM, Sang pham van <pvsang002 at gmail.com> wrote:
> Hi,
> I am using DM structure and SNES to solve a 3D problem. In the problem I have 3 variables.
> I got SNES converged with a grid. Obtain result are physically right. However when I refine the grid, SNES does not always converge,
   With the refined grid how are you starting the solution? Do you use the interpolated solution from the coarser grid (called grid sequencing) or just some “not good” initial guess?
> the reason of divergence is line search fail or linear solver failed. (I also tried other type of SNES, line search seems to be the one best fits my problem)
> Can you please give me a suggestion to figure out the problem with my solver? What options should I use to have pure Newton method in SNES? Is there any advance option I can use with line search to improve SNES convergence.
   You should use grid sequencing, not only does it get convergence when you may not otherwise get it but it will also solve the problem faster. With PETSc DM you can use -snes_grid_sequence n  or SNESSetGridSequence() in the code to do n levels of grid sequencing.
   Barry
> Thank you very much.
> Minh.
