[petsc-users] SNES divergence
Sang pham van pvsang002 at gmail.com
Tue Jun 17 14:30:11 CDT 2014
Thanks Barry,
To refine the grid, I just put more points in the direction. For both fine
and coarse meshes, I used simple initial guess (say constant values in
whole domain for all variables).
By using grid sequencing, is the finest mesh is the one I first input the
solver?
Can you let me know what options should I use to have pure Newton method?
S.
On Tue, Jun 17, 2014 at 3:20 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jun 17, 2014, at 2:12 PM, Sang pham van <pvsang002 at gmail.com> wrote:
> > Hi,
> > I am using DM structure and SNES to solve a 3D problem. In the problem I
> have 3 variables.
> > I got SNES converged with a grid. Obtain result are physically right.
> However when I refine the grid, SNES does not always converge,
>    With the refined grid how are you starting the solution? Do you use the
> interpolated solution from the coarser grid (called grid sequencing) or
> just some “not good” initial guess?
> > the reason of divergence is line search fail or linear solver failed. (I
> also tried other type of SNES, line search seems to be the one best fits my
> problem)
> > Can you please give me a suggestion to figure out the problem with my
> solver? What options should I use to have pure Newton method in SNES? Is
> there any advance option I can use with line search to improve SNES
> convergence.
>    You should use grid sequencing, not only does it get convergence when
> you may not otherwise get it but it will also solve the problem faster.
> With PETSc DM you can use -snes_grid_sequence n  or SNESSetGridSequence()
> in the code to do n levels of grid sequencing.
>    Barry
> > Thank you very much.
> > Minh.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140617/b39a93a1/attachment.html>
