[petsc-users] error in mpiaij with unkown soruce
Jed Brown jed at jedbrown.org
Tue Jul 1 04:08:09 CDT 2014
Thorsten Kersting <Thorsten.Kersting at itp1.uni-stuttgart.de> writes:
> Yes the error is reproducible and happens at the same place.
> I only set values on those processes, on which they are stored (I
> calculate them directly before setting them). And with every matrix I do
> this only once, so if i understand correctly, MAT_FINAL_ASSAMEBLY is
> sufficient. but i can try and see if it is different with
> MAT_FLUSH_ASSEMBLY.
Sounds like a system problem.  Can you try a smaller problem size and
run in a debugger?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140701/1a6293d8/attachment.pgp>
