[petsc-users] error in mpiaij with unkown soruce
Matthew Knepley
knepley at gmail.com
Tue Jul 1 04:38:17 CDT 2014
On Tue, Jul 1, 2014 at 11:00 AM, Thorsten Kersting <
Thorsten.Kersting at itp1.uni-stuttgart.de> wrote:
> Hello!
> thanks for the quick answer.
> Yes the error is reproducible and happens at the same place.
> I only set values on those processes, on which they are stored (I
> calculate them directly before setting them). And with every matrix I do
> this only once, so if i understand correctly, MAT_FINAL_ASSAMEBLY is
> sufficient. but i can try and see if it is different with
> MAT_FLUSH_ASSEMBLY.
I recommend using valgrind on this. Its possible that you have overwritten
memory.
Matt
> On 07/01/2014 10:43 AM, Jed Brown wrote:
>> Thorsten Kersting <Thorsten.Kersting at itp1.uni-stuttgart.de> writes:
>> Hello everyone!
>>> I want so solve eigenvalues of a matrix, which has a complicated
>>> structure, with SLEPC. I get the following error while setting up the
>>> EPS Problem. But I dont understand the error, and how to fix it. Does
>>> anyone have an idea? Or do you need more information (and which
>>> information exactly)?
>> Is the error reproducible and if so, does it happen at the same place?
>> Is it possible that you are setting many off-process values? You might
>> need to assemble sooner with MAT_FLUSH_ASSEMBLY so that the stash does
>> not grow too large for whatever resource limits may have been placed on
>> your job.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140701/5ec0c577/attachment.html>
