[petsc-users] error in mpiaij with unkown soruce
Thorsten Kersting Thorsten.Kersting at itp1.uni-stuttgart.de
Tue Jul 1 04:00:28 CDT 2014
Hello!
thanks for the quick answer.
Yes the error is reproducible and happens at the same place.
I only set values on those processes, on which they are stored (I
calculate them directly before setting them). And with every matrix I do
this only once, so if i understand correctly, MAT_FINAL_ASSAMEBLY is
sufficient. but i can try and see if it is different with
MAT_FLUSH_ASSEMBLY.
On 07/01/2014 10:43 AM, Jed Brown wrote:
> Thorsten Kersting <Thorsten.Kersting at itp1.uni-stuttgart.de> writes:
>> Hello everyone!
>> I want so solve eigenvalues of a matrix, which has a complicated
>> structure, with SLEPC. I get the following error while setting up the
>> EPS Problem. But I dont understand the error, and how to fix it. Does
>> anyone have an idea? Or do you need more information (and which
>> information exactly)?
> Is the error reproducible and if so, does it happen at the same place?
> Is it possible that you are setting many off-process values?  You might
> need to assemble sooner with MAT_FLUSH_ASSEMBLY so that the stash does
> not grow too large for whatever resource limits may have been placed on
> your job.
