[petsc-users] How to configure PETSc with gcc-4.9
Matthew Knepley
knepley at gmail.com
Thu Apr 24 20:35:30 CDT 2014
On Thu, Apr 24, 2014 at 9:27 PM, Justin Dong <jsd1 at rice.edu> wrote:
> Hi all,
> I'm trying to configure PETSc on Mac OS X with gcc-4.9. Currently, it's
> configured with gcc that comes with Xcode, but I want to use gcc-4.9 that I
> installed myself. I try:
> ./configure --with-cc=gcc-4.9 --with-fc=gfortran
> --download-f-blas-lapack --download-mpich
> But while configuring MPICH it gets stuck indefinitely. I've included the
> output below after I terminate the process. I don't have this issue if I
> just configure with cc=gcc. Any ideas what the problem is here?
>From the stack trace, its just taking a long time. If it overruns the
timeout, it should just die. You can try
running using -useThreads=0 if you suspect the timeout is not working.
Matt
> ^CTraceback (most recent call last):
> File "./configure", line 10, in <module>
> execfile(os.path.join(os.path.dirname(__file__), 'config',
> 'configure.py'))
> File "./config/configure.py", line 372, in <module>
> petsc_configure([])
> File "./config/configure.py", line 287, in petsc_configure
> framework.configure(out = sys.stdout)
> File
> "/Users/justindong/Classes/CAAMResearch/petsc-3.4.4/config/BuildSystem/config/framework.py",
> line 933, in configure
> child.configure()
> File
> "/Users/justindong/Classes/CAAMResearch/petsc-3.4.4/config/BuildSystem/config/package.py",
> line 558, in configure
> self.executeTest(self.configureLibrary)
> File
> "/Users/justindong/Classes/CAAMResearch/petsc-3.4.4/config/BuildSystem/config/base.py",
> line 115, in executeTest
> ret = apply(test, args,kargs)
> File
> "/Users/justindong/Classes/CAAMResearch/petsc-3.4.4/config/BuildSystem/config/packages/MPI.py",
> line 748, in configureLibrary
> config.package.Package.configureLibrary(self)
> File
> line 486, in configureLibrary
> for location, directory, lib, incl in self.generateGuesses():
> File
> line 232, in generateGuesses
> d = self.checkDownload(1)
> File
> line 351, in checkDownload
> return config.package.Package.checkDownload(self, requireDownload)
> File
> line 340, in checkDownload
> return self.getInstallDir()
> File
> line 187, in getInstallDir
> return os.path.abspath(self.Install())
> File
> line 366, in Install
> return self.InstallMPICH()
> File
> line 544, in InstallMPICH
> output,err,ret = config.base.Configure.executeShellCommand('cd
> '+mpichDir+' && ./configure '+args, timeout=2000, log = self.framework.log)
> File
> "/Users/justindong/Classes/CAAMResearch/petsc-3.4.4/config/BuildSystem/script.py",
> line 254, in executeShellCommand
> (output, error, status) = runInShell(command, log, cwd)
> File
> line 243, in runInShell
> thread.join(timeout)
> File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/threading.py",
> line 958, in join
> self.__block.wait(delay)
> File
> line 358, in wait
> _sleep(delay)
> KeyboardInterrupt
> Sincerely,
> Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140424/86344264/attachment-0001.html>
