[petsc-users] How to configure PETSc with gcc-4.9
Justin Dong
jsd1 at rice.edu
Thu Apr 24 20:27:34 CDT 2014
Hi all,
I'm trying to configure PETSc on Mac OS X with gcc-4.9. Currently, it's
configured with gcc that comes with Xcode, but I want to use gcc-4.9 that I
installed myself. I try:
./configure --with-cc=gcc-4.9 --with-fc=gfortran --download-f-blas-lapack
--download-mpich
But while configuring MPICH it gets stuck indefinitely. I've included the
output below after I terminate the process. I don't have this issue if I
just configure with cc=gcc. Any ideas what the problem is here?
^CTraceback (most recent call last):
File "./configure", line 10, in <module>
execfile(os.path.join(os.path.dirname(__file__), 'config',
'configure.py'))
File "./config/configure.py", line 372, in <module>
petsc_configure([])
File "./config/configure.py", line 287, in petsc_configure
framework.configure(out = sys.stdout)
File
"/Users/justindong/Classes/CAAMResearch/petsc-3.4.4/config/BuildSystem/config/framework.py",
line 933, in configure
child.configure()
File
"/Users/justindong/Classes/CAAMResearch/petsc-3.4.4/config/BuildSystem/config/package.py",
line 558, in configure
self.executeTest(self.configureLibrary)
File
"/Users/justindong/Classes/CAAMResearch/petsc-3.4.4/config/BuildSystem/config/base.py",
line 115, in executeTest
ret = apply(test, args,kargs)
File
"/Users/justindong/Classes/CAAMResearch/petsc-3.4.4/config/BuildSystem/config/packages/MPI.py",
line 748, in configureLibrary
config.package.Package.configureLibrary(self)
File
line 486, in configureLibrary
for location, directory, lib, incl in self.generateGuesses():
File
line 232, in generateGuesses
d = self.checkDownload(1)
File
line 351, in checkDownload
return config.package.Package.checkDownload(self, requireDownload)
File
line 340, in checkDownload
return self.getInstallDir()
File
line 187, in getInstallDir
return os.path.abspath(self.Install())
File
line 366, in Install
return self.InstallMPICH()
File
line 544, in InstallMPICH
output,err,ret = config.base.Configure.executeShellCommand('cd
'+mpichDir+' && ./configure '+args, timeout=2000, log = self.framework.log)
File
"/Users/justindong/Classes/CAAMResearch/petsc-3.4.4/config/BuildSystem/script.py",
line 254, in executeShellCommand
(output, error, status) = runInShell(command, log, cwd)
File
line 243, in runInShell
thread.join(timeout)
File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/threading.py",
line 958, in join
self.__block.wait(delay)
File
line 358, in wait
_sleep(delay)
KeyboardInterrupt
Sincerely,
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140424/2c94b59a/attachment.html>
