[petsc-users] Compiling PETSc 3.4.3 with ICC 14.0 and OpenMPI	1.6.5
    Matthew Knepley
    knepley at gmail.com
    Thu Oct 31 10:55:04 CDT 2013
On Thu, Oct 31, 2013 at 10:47 AM, Maxime Boissonneault <
maxime.boissonneault at calculquebec.ca> wrote:
>  Here is the configure.log with debugging.
Same compiler bug
  make[1]: Leaving directory
`/software6/src/petsc-3.4.3-intel-try/externalpackages/SuperLU_DIST_3.3/SRC'
error #13002: unexpected CFE message argument:  e. The staggered
cosine transform may be
warning #13003: message verification failed for: 556; reverting to
internal message
I am afraid if  you want SuperLU, you will have to revert to a non-buggy
release of ICC or use GNU.
     Matt
Maxime
> Le 2013-10-30 17:56, Matthew Knepley a écrit :
> On Wed, Oct 30, 2013 at 4:55 PM, Maxime Boissonneault <
>>  Le 2013-10-30 17:50, Matthew Knepley a écrit :
>> On Wed, Oct 30, 2013 at 4:48 PM, Maxime Boissonneault <
>>> Le 2013-10-30 17:45, Matthew Knepley a écrit :
>>> On Wed, Oct 30, 2013 at 4:41 PM, Maxime Boissonneault <
>>>>  Hi,
>>>> Here is the attached configure.log file.
>>>> I will try the flag --with-debugging tomorrow.
>>>  Get rid of -O2: CFLAGS="-O2 -xHost -mkl -fPIC -m64" FFLAGS="-O2 -xHost
>>> -mkl -fPIC -m64" --prefix=/software6/libs/petsc/3.4.3_intel
>>> I had -O3 earlier. The error was the same. It is overwritten by the
>>> makefile anyway if you look in the details. This is not the source of the
>>> problem.
>>  I know, but if you leave it there with you use --with-debugging, it
>> could still cause the problem.
>>>   --with-dynamic-loading
>>> --with-x=0 --with-mpi-compilers=1
>>> --with-mpi-dir=/software6/mpi/openmpi/1.6.5_intel
>>>  --known-mpi-shared-libraries=1
>>> --with-debugging=no
>>> --with-shared-libraries=1
>>> --with-blas-lapack-dir=/software6/compilers/intel/composer_xe_2013_sp1/lib/intel64
>>> Don't need this --with-scalapack=1
>>> --with-scalapack-include=/software6/compilers/intel/composer_xe_2013_sp1/include
>>> --with-scalapack-lib=/software6/compilers/intel/composer_xe_2013_sp1/lib/intel64/libmkl_scalapack_lp64.a
>>> Don't need this --with-blacs=1
>>> --with-blacs-include=/software6/compilers/intel/composer_xe_2013_sp1/include
>>> --with-blacs-lib=/software6/compilers/intel/composer_xe_2013_sp1/lib/intel64/libmkl_blacs_openmpi_lp64.a
>>> --download-mumps=yes
>>> --download-ptscotch=1
>>> --download-superlu=yes
>>> --download-superlu_dist=yes
>>>  --download-parmetis=yes
>>> --download-metis=yes
>>> --download-ml=yes
>>> This is deprecated. Use -pc_type gamg --download-prometheus=yes
>>> Which part is, download-ml ? or download-hypre ? Again, this is not the
>>> module that fails compiling however.
>>  I do not understand the question here. ML is algebraic multigrid,
>> similar to -pc_type gamg. Hypre has a few things in it.
>>    Some context : I am a system administrator installing this library
>> using the package list given to me by the user who will use it. I do not
>> know the details of what each package does.
>> I do not understand which part is depecrated and what I should replace
>> with -pc_type gamg.
>  The package 'prometheus' is deprecated. The same functionality is now
> available from within the library, so
> just remove --download-prometheus.
>    Thanks,
>       Matt
>>       Matt
>>>  Maxime
>>>  --download-hypre=yes
>>>    Matt
>>>>  Maxime
>>>> Le 2013-10-30 16:49, Matthew Knepley a écrit :
>>>> On Wed, Oct 30, 2013 at 3:39 PM, Maxime Boissonneault <
>>>>>  Hi,
>>>>> I am currently trying to compile PETSc 3.4.3 with ICC 14.0 and OpenMPI
>>>>> 1.6.5 and it fails SuperLU_Dist.
>>>>> I am getting the following error :
>>>>> 68303 /software6/mpi/openmpi/1.6.5_intel/bin/mpicc
>>>>> -I/software6/mpi/openmpi/1.6.5_intel/include
>>>>> -I/software6/mpi/openmpi/1.6.5_intel/include -O2 -xHost -mkl -fPIC -m64
>>>>> -fPIC -O3  -DAdd_ -DUSE_VENDOR_BLAS -c pdgstrf.c
>>>>> 68304 make[1]: Leaving directory
>>>>> 68305 error #13002: unexpected CFE message argument:  e. The staggered
>>>>> 68306 warning #13003: message verification failed for: 556; reverting
>>>>> to internal message
>>>>> 68307 pdgstrf.c(2672): warning #556: a value of type "int" cannot be
>>>>> assigned to an entity of type "MPI_Request"
>>>>> 68308             U_diag_blk_send_req[krow] = 1; /* flag outstanding
>>>>> Isend */
>>>>> 68309                                       ^
>>>>> 68310
>>>>> 68311 pdgstrf.c(2672): warning #152: Fatal error: Trigonometric
>>>>> Transform has failed to release the memory.
>>>>> 68312             U_diag_blk_send_req[krow] = 1; /* flag outstanding
>>>>> Isend */
>>>>> 68313                                         ^
>>>>> 68314
>>>>> 68315 compilation aborted for pdgstrf.c (code 1)
>>>>> 68316 make[1]: *** [pdgstrf.o] Error 1
>>>>> Anyone has a clue on to what might be going on ?
>>>>  1) Always send configure.log
>>>>  2) It looks like an Intel compiler bug. Try building with
>>>> --with-debugging first
>>>>    Matt
>>>>> Analyste de calcul - Calcul Québec, Université Laval
>>>>> Ph. D. en physique
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> Ph. D. en physique
>>> experiments lead.
>>> -- Norbert Wiener
>>> Ph. D. en physique
>> experiments lead.
>> -- Norbert Wiener
>> Ph. D. en physique
> experiments lead.
> -- Norbert Wiener
> Ph. D. en physique
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131031/09aafb26/attachment-0001.html>
