[petsc-users] Can I eliminate all mallocs in parallel matrix assembly?
Matthew Knepley
knepley at gmail.com
Wed Oct 16 10:18:01 CDT 2013
On Wed, Oct 16, 2013 at 10:10 AM, Markus Berndt <berndt at lanl.gov> wrote:
> I am setting MAT_NEW_NONZERO_ALLOCATION_ERR to PETSC_FALSE, the PETSc
> version is 3.3-p6.
> Thanks for clarifying this. Just to make sure I understand correctly, by
> providing the correct values in d_nnz and o_nnz I should always be able to
> avoid any mallocs in matrix assembly?
Yes.
Matt
> I will dig in with a debugger as you suggest
> Thanks
> - Markus
> On 10/16/2013 08:57 AM, Jed Brown wrote:
>> Markus Berndt <berndt at lanl.gov> writes:
>> I am trying to minimize the memory footprint of an application by
>>> specifying exactly how many nonzeros are needed per row of the matrix. I
>>> am pretty sure that I am correctly calculating these memory requirements
>>> for the diagonal and off diagonal parts of the parallel matrix (I am
>>> using MatCreateAIJ).
>> Either you have called another function later that clears the
>> preallocation information or the information you provided is incorrect.
>> What version of PETSc are you using? We currently set
>> MAT_NEW_NONZERO_ALLOCATION_ERR by default so you should get an error
>> when a new nonzero triggers allocation. You can catch that in a
>> debugger and figure out why there are more nonzeros than you allocated
>> for.
> Markus Berndt - CCS-2 - LANL - 505-665-4711
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131016/dbe9231f/attachment-0001.html>
