[petsc-users] Can I eliminate all mallocs in parallel matrix assembly?
Markus Berndt
berndt at lanl.gov
Wed Oct 16 10:10:40 CDT 2013
I am setting MAT_NEW_NONZERO_ALLOCATION_ERR to PETSC_FALSE, the PETSc
version is 3.3-p6.
Thanks for clarifying this. Just to make sure I understand correctly, by
providing the correct values in d_nnz and o_nnz I should always be able
to avoid any mallocs in matrix assembly?
I will dig in with a debugger as you suggest
Thanks
- Markus
On 10/16/2013 08:57 AM, Jed Brown wrote:
> Markus Berndt <berndt at lanl.gov> writes:
>> I am trying to minimize the memory footprint of an application by
>> specifying exactly how many nonzeros are needed per row of the matrix. I
>> am pretty sure that I am correctly calculating these memory requirements
>> for the diagonal and off diagonal parts of the parallel matrix (I am
>> using MatCreateAIJ).
> Either you have called another function later that clears the
> preallocation information or the information you provided is incorrect.
> What version of PETSc are you using? We currently set
> MAT_NEW_NONZERO_ALLOCATION_ERR by default so you should get an error
> when a new nonzero triggers allocation. You can catch that in a
> debugger and figure out why there are more nonzeros than you allocated
> for.
Markus Berndt - CCS-2 - LANL - 505-665-4711
