[petsc-users] signal received error; MatNullSpaceTest; Stokes flow solver with pc fieldsplit and schur complement
Dave May dave.mayhem23 at gmail.com
Wed Oct 16 09:32:56 CDT 2013
Sounds like a memory error.
I'd run your code through valgrind to double check. The error could be
completely unconnected to the nullspaces.
Cheers,
  Dave
On 16 October 2013 16:18, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> Dear all,
> I'm trying to solve a stokes flow with constant viscosity but with
> non-zero divergence prescribed in the rhs.
> I have a matrix created from DMDA (mDa) of 4 dofs: vx, vy, vz and p
> respectively.
> I have another DMDA (mDaP) of same size but of 1 dof corresponding to only
> p.
> I have assigned the null space for constant pressure inside the code. I
> have assigned two nullspace basis:  One corresponding to vector created
> from mDa that is assigned to outer ksp. Second corresponding to vector
> created from mDaP that is assigned to a ksp obtained from the fieldsplit
> corresponding to the schur complement.
> Now when running the code, the solver converges for up to certain size,
> e.g. 92X110 X 92 (the results for this convegent case with -ksp_view is
> given at the end of the emal.
> But when I double the size of the grid in each dimension, it gives me a
> run-time error.
> The options  I've used are of the kind:
> -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_dm_splits 0
> -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3
> -fieldsplit_0_pc_type hypre -fieldsplit_0_ksp_converged_reason
> -fieldsplit_1_ksp_converged_reason -ksp_converged_reason -ksp_view
> Here are:
> 1. Error message when using hypre for fieldsplit_0
> 2. Error message when using gamg for fieldsplit_0
> 3. -ksp_view of the working case using hypre for filedsplit_0
> I get following error when I use hypre :
> 1.
> [5]PETSC ERROR: --------------------- Error Message
> [5]PETSC ERROR: Signal received!
> [5]PETSC ERROR:
> [5]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
> [5]PETSC ERROR: See docs/changes/index.html for recent updates.
> [5]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [5]PETSC ERROR: See docs/index.html for manual pages.
> [5]PETSC ERROR:
> [5]PETSC ERROR:
> /epi/asclepios2/bkhanal/works/AdLemModel/build/src/AdLemMain on a
> arch-linux2-cxx-debug named nef001 by bkhanal Wed Oct 16 15:08:42 2013
> [5]PETSC ERROR: Libraries linked from
> /epi/asclepios2/bkhanal/petscDebug/lib
> [5]PETSC ERROR: Configure run at Wed Oct 16 14:18:48 2013
> [5]PETSC ERROR: Configure options --with-mpi-dir=/opt/openmpi-gcc/current/
> --with-shared-libraries --prefix=/epi/asclepios2/bkhanal/petscDebug
> -download-f-blas-lapack=1 --download-metis --download-parmetis
> --download-superlu_dist --download-scalapack --download-mumps
> --download-hypre --with-clanguage=cxx
> [5]PETSC ERROR:
> [5]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> [6]PETSC ERROR:
> [6]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the
> batch system) has told this process to end
> [6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [6]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[6]PETSCERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [6]PETSC ERROR: likely location of problem given in stack below
> [6]PETSC ERROR: ---------------------  Stack Frames
> [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [6]PETSC ERROR:       INSTEAD the line number of the start of the function
> [6]PETSC ERROR:       is given.
> [6]PETSC ERROR: [6] HYPRE_SetupXXX line 130
> /tmp/petsc-3.4.3/src/ksp/pc/impls/hypre/hypre.c
> [6]PETSC ERROR: [6] PCSetUp_HYPRE line 94
> [6]PETSC ERROR: [6] PCSetUp line 868
> /tmp/petsc-3.4.3/src/ksp/pc/interface/precon.c
> [6]PETSC ERROR: [6] KSPSetUp line 192
> /tmp/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
> [6]PETSC ERROR: [6] KSPSolve line 356
> [6]PETSC ERROR: [6] MatMult_SchurComplement line 75
> /tmp/petsc-3.4.3/src/ksp/ksp/utils/schurm.c
> [6]PETSC ERROR: [6] MatNullSpaceTest line 408
> /tmp/petsc-3.4.3/src/mat/interface/matnull.c
> [6]PETSC ERROR: [6] solveModel line 113
> "unknowndirectory/"/epi/asclepios2/bkhanal/works/AdLemModel/src/PetscAdLemTaras3D.cxx
> 2.
> Using gamg instead has errors like following:
> [5]PETSC ERROR: ---------------------  Stack Frames
> [5]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [5]PETSC ERROR:       INSTEAD the line number of the start of the function
> [5]PETSC ERROR:       is given.
> [5]PETSC ERROR: [5] PetscLLCondensedAddSorted line 1202
> /tmp/petsc-3.4.3/include/petsc-private/matimpl.h
> [5]PETSC ERROR: [5] MatPtAPSymbolic_MPIAIJ_MPIAIJ line 124
> /tmp/petsc-3.4.3/src/mat/impls/aij/mpi/mpiptap.c
> [5]PETSC ERROR: [5] MatPtAP_MPIAIJ_MPIAIJ line 80
> [5]PETSC ERROR: [5] MatPtAP line 8223
> /tmp/petsc-3.4.3/src/mat/interface/matrix.c
> [5]PETSC ERROR: [5] createLevel line 144
> /tmp/petsc-3.4.3/src/ksp/pc/impls/gamg/gamg.c
> [5]PETSC ERROR: [5] PCSetUp_GAMG line 545
> [5]PETSC ERROR: [5] PCSetUp line 868
> [5]PETSC ERROR: [5] KSPSetUp line 192
> [5]PETSC ERROR: [5] KSPSolve line 356
> [5]PETSC ERROR: [5] MatMult_SchurComplement line 75
> [5]PETSC ERROR: [5] MatNullSpaceTest line 408
> [5]PETSC ERROR: [5] solveModel line 113
> 3.
> BUT, It does give me results when I use a domain of size: 91X109 X 91
> (half sized in each dimension) The result along with ksp view in this case
> is as follows:
> Linear solve converged due to CONVERGED_RTOL iterations 2
> KSP Object: 64 MPI processes
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>   left preconditioning
>   has attached null space
>   using PRECONDITIONED norm type for convergence test
> PC Object: 64 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, blocksize = 4, factorization FULL
>     Preconditioner for the Schur complement formed from user provided
> matrix
>     Split info:
>     Split number 0 Fields  0, 1, 2
>     Split number 1 Fields  3
>     KSP solver for A00 block
>       KSP Object:      (fieldsplit_0_)       64 MPI processes
>         type: gmres
>       PC Object:      (fieldsplit_0_)       64 MPI processes
>         type: hypre
>           HYPRE BoomerAMG preconditioning
>           HYPRE BoomerAMG: Cycle type V
>           HYPRE BoomerAMG: Maximum number of levels 25
>           HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
>           HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
>           HYPRE BoomerAMG: Threshold for strong coupling 0.25
>           HYPRE BoomerAMG: Interpolation truncation factor 0
>           HYPRE BoomerAMG: Interpolation: max elements per row 0
>           HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
>           HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
>           HYPRE BoomerAMG: Maximum row sums 0.9
>           HYPRE BoomerAMG: Sweeps down         1
>           HYPRE BoomerAMG: Sweeps up           1
>           HYPRE BoomerAMG: Sweeps on coarse    1
>           HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
>           HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
>           HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
>           HYPRE BoomerAMG: Relax weight  (all)      1
>           HYPRE BoomerAMG: Outer relax weight (all) 1
>           HYPRE BoomerAMG: Using CF-relaxation
>           HYPRE BoomerAMG: Measure type        local
>           HYPRE BoomerAMG: Coarsen type        Falgout
>           HYPRE BoomerAMG: Interpolation type  classical
>         linear system matrix = precond matrix:
>         Matrix Object:         64 MPI processes
>           type: mpiaij
>           rows=2793120, cols=2793120
>           total: nonzeros=221624352, allocated nonzeros=221624352
>           total number of mallocs used during MatSetValues calls =0
>             using I-node (on process 0) routines: found 14812 nodes, limit
> used is 5
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object:      (fieldsplit_1_)       64 MPI processes
>         type: gmres
>       PC Object:      (fieldsplit_1_)       64 MPI processes
>         type: bjacobi
>           block Jacobi: number of blocks = 64
>           Local solve is same for all blocks, in the following KSP and PC
> objects:
>         KSP Object:        (fieldsplit_1_sub_)         1 MPI processes
>           type: preonly
>           using NONE norm type for convergence test
>         PC Object:        (fieldsplit_1_sub_)         1 MPI processes
>           type: ilu
>             ILU: out-of-place factorization
>             0 levels of fill
>             tolerance for zero pivot 2.22045e-14
>             using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>             matrix ordering: natural
>             factor fill ratio given 1, needed 1
>               Factored matrix follows:
>                 Matrix Object:                 1 MPI processes
>                   type: seqaij
>                   rows=14812, cols=14812
>                   package used to perform factorization: petsc
>                   total: nonzeros=368098, allocated nonzeros=368098
>                     not using I-node routines
>             type: seqaij
>         linear system matrix followed by preconditioner matrix:
>           type: schurcomplement
>           rows=931040, cols=931040
>             Schur complement A11 - A10 inv(A00) A01
>             A11
>                 type: mpiaij
>                 total: nonzeros=24624928, allocated nonzeros=24624928
>                   not using I-node (on process 0) routines
>             A10
>                 type: mpiaij
>                 rows=931040, cols=2793120
>                 total: nonzeros=73874784, allocated nonzeros=73874784
>             KSP of A00
> MPI processes
>                 type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
> divergence=10000
> processes
>                 type: hypre
> call 1
> coarsening 0
> coarsening 1
>                   type: mpiaij
> nodes, limit used is 5
>             A01
>                 type: mpiaij
>                 rows=2793120, cols=931040
> limit used is 5
>           type: mpiaij
>     type: mpiaij
>     rows=3724160, cols=3724160, bs=4
>     total: nonzeros=393998848, allocated nonzeros=393998848
> What could be going wrong here ? Is it something related to null-space
> setting ? But I do not know why it does not arise for smaller domain sizes!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131016/7019c46a/attachment-0001.html>
