[petsc-users] signal received error; MatNullSpaceTest; Stokes flow solver with pc fieldsplit and schur complement
Bishesh Khanal bisheshkh at gmail.com
Wed Oct 16 09:18:01 CDT 2013
Dear all,
I'm trying to solve a stokes flow with constant viscosity but with non-zero
divergence prescribed in the rhs.
I have a matrix created from DMDA (mDa) of 4 dofs: vx, vy, vz and p
respectively.
I have another DMDA (mDaP) of same size but of 1 dof corresponding to only
p.
I have assigned the null space for constant pressure inside the code. I
have assigned two nullspace basis:  One corresponding to vector created
from mDa that is assigned to outer ksp. Second corresponding to vector
created from mDaP that is assigned to a ksp obtained from the fieldsplit
corresponding to the schur complement.
Now when running the code, the solver converges for up to certain size,
e.g. 92X110 X 92 (the results for this convegent case with -ksp_view is
given at the end of the emal.
But when I double the size of the grid in each dimension, it gives me a
run-time error.
The options  I've used are of the kind:
-pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_dm_splits 0
-pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3
-fieldsplit_0_pc_type hypre -fieldsplit_0_ksp_converged_reason
-fieldsplit_1_ksp_converged_reason -ksp_converged_reason -ksp_view
Here are:
1. Error message when using hypre for fieldsplit_0
2. Error message when using gamg for fieldsplit_0
3. -ksp_view of the working case using hypre for filedsplit_0
I get following error when I use hypre :
1.
[5]PETSC ERROR: --------------------- Error Message
[5]PETSC ERROR: Signal received!
[5]PETSC ERROR:
[5]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[5]PETSC ERROR: See docs/changes/index.html for recent updates.
[5]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[5]PETSC ERROR: See docs/index.html for manual pages.
[5]PETSC ERROR:
[5]PETSC ERROR:
/epi/asclepios2/bkhanal/works/AdLemModel/build/src/AdLemMain on a
arch-linux2-cxx-debug named nef001 by bkhanal Wed Oct 16 15:08:42 2013
[5]PETSC ERROR: Libraries linked from /epi/asclepios2/bkhanal/petscDebug/lib
[5]PETSC ERROR: Configure run at Wed Oct 16 14:18:48 2013
[5]PETSC ERROR: Configure options --with-mpi-dir=/opt/openmpi-gcc/current/
--with-shared-libraries --prefix=/epi/asclepios2/bkhanal/petscDebug
-download-f-blas-lapack=1 --download-metis --download-parmetis
--download-superlu_dist --download-scalapack --download-mumps
--download-hypre --with-clanguage=cxx
[5]PETSC ERROR:
[5]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[6]PETSC ERROR:
[6]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the
batch system) has told this process to end
[6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[6]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[6]PETSC ERROR:
or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
corruption errors
[6]PETSC ERROR: likely location of problem given in stack below
[6]PETSC ERROR: ---------------------  Stack Frames
[6]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[6]PETSC ERROR:       INSTEAD the line number of the start of the function
[6]PETSC ERROR:       is given.
[6]PETSC ERROR: [6] HYPRE_SetupXXX line 130
/tmp/petsc-3.4.3/src/ksp/pc/impls/hypre/hypre.c
[6]PETSC ERROR: [6] PCSetUp_HYPRE line 94
[6]PETSC ERROR: [6] PCSetUp line 868
/tmp/petsc-3.4.3/src/ksp/pc/interface/precon.c
[6]PETSC ERROR: [6] KSPSetUp line 192
/tmp/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
[6]PETSC ERROR: [6] KSPSolve line 356
[6]PETSC ERROR: [6] MatMult_SchurComplement line 75
/tmp/petsc-3.4.3/src/ksp/ksp/utils/schurm.c
[6]PETSC ERROR: [6] MatNullSpaceTest line 408
/tmp/petsc-3.4.3/src/mat/interface/matnull.c
[6]PETSC ERROR: [6] solveModel line 113
"unknowndirectory/"/epi/asclepios2/bkhanal/works/AdLemModel/src/PetscAdLemTaras3D.cxx
2.
Using gamg instead has errors like following:
[5]PETSC ERROR: ---------------------  Stack Frames
[5]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[5]PETSC ERROR:       INSTEAD the line number of the start of the function
[5]PETSC ERROR:       is given.
[5]PETSC ERROR: [5] PetscLLCondensedAddSorted line 1202
/tmp/petsc-3.4.3/include/petsc-private/matimpl.h
[5]PETSC ERROR: [5] MatPtAPSymbolic_MPIAIJ_MPIAIJ line 124
/tmp/petsc-3.4.3/src/mat/impls/aij/mpi/mpiptap.c
[5]PETSC ERROR: [5] MatPtAP_MPIAIJ_MPIAIJ line 80
[5]PETSC ERROR: [5] MatPtAP line 8223
/tmp/petsc-3.4.3/src/mat/interface/matrix.c
[5]PETSC ERROR: [5] createLevel line 144
/tmp/petsc-3.4.3/src/ksp/pc/impls/gamg/gamg.c
[5]PETSC ERROR: [5] PCSetUp_GAMG line 545
[5]PETSC ERROR: [5] PCSetUp line 868
[5]PETSC ERROR: [5] KSPSetUp line 192
[5]PETSC ERROR: [5] KSPSolve line 356
[5]PETSC ERROR: [5] MatMult_SchurComplement line 75
[5]PETSC ERROR: [5] MatNullSpaceTest line 408
[5]PETSC ERROR: [5] solveModel line 113
3.
BUT, It does give me results when I use a domain of size: 91X109 X 91 (half
sized in each dimension) The result along with ksp view in this case is as
follows:
Linear solve converged due to CONVERGED_RTOL iterations 2
KSP Object: 64 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using PRECONDITIONED norm type for convergence test
PC Object: 64 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, blocksize = 4, factorization FULL
    Preconditioner for the Schur complement formed from user provided matrix
    Split info:
    Split number 0 Fields  0, 1, 2
    Split number 1 Fields  3
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       64 MPI processes
        type: gmres
      PC Object:      (fieldsplit_0_)       64 MPI processes
        type: hypre
          HYPRE BoomerAMG preconditioning
          HYPRE BoomerAMG: Cycle type V
          HYPRE BoomerAMG: Maximum number of levels 25
          HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
          HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
          HYPRE BoomerAMG: Threshold for strong coupling 0.25
          HYPRE BoomerAMG: Interpolation truncation factor 0
          HYPRE BoomerAMG: Interpolation: max elements per row 0
          HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
          HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
          HYPRE BoomerAMG: Maximum row sums 0.9
          HYPRE BoomerAMG: Sweeps down         1
          HYPRE BoomerAMG: Sweeps up           1
          HYPRE BoomerAMG: Sweeps on coarse    1
          HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
          HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
          HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
          HYPRE BoomerAMG: Relax weight  (all)      1
          HYPRE BoomerAMG: Outer relax weight (all) 1
          HYPRE BoomerAMG: Using CF-relaxation
          HYPRE BoomerAMG: Measure type        local
          HYPRE BoomerAMG: Coarsen type        Falgout
          HYPRE BoomerAMG: Interpolation type  classical
        linear system matrix = precond matrix:
        Matrix Object:         64 MPI processes
          type: mpiaij
          rows=2793120, cols=2793120
          total: nonzeros=221624352, allocated nonzeros=221624352
          total number of mallocs used during MatSetValues calls =0
            using I-node (on process 0) routines: found 14812 nodes, limit
used is 5
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_1_)       64 MPI processes
        type: gmres
      PC Object:      (fieldsplit_1_)       64 MPI processes
        type: bjacobi
          block Jacobi: number of blocks = 64
          Local solve is same for all blocks, in the following KSP and PC
objects:
        KSP Object:        (fieldsplit_1_sub_)         1 MPI processes
          type: preonly
          using NONE norm type for convergence test
        PC Object:        (fieldsplit_1_sub_)         1 MPI processes
          type: ilu
            ILU: out-of-place factorization
            0 levels of fill
            tolerance for zero pivot 2.22045e-14
            using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
            matrix ordering: natural
            factor fill ratio given 1, needed 1
              Factored matrix follows:
                Matrix Object:                 1 MPI processes
                  type: seqaij
                  rows=14812, cols=14812
                  package used to perform factorization: petsc
                  total: nonzeros=368098, allocated nonzeros=368098
                    not using I-node routines
            type: seqaij
        linear system matrix followed by preconditioner matrix:
          type: schurcomplement
          rows=931040, cols=931040
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: mpiaij
                total: nonzeros=24624928, allocated nonzeros=24624928
                  not using I-node (on process 0) routines
            A10
                type: mpiaij
                rows=931040, cols=2793120
                total: nonzeros=73874784, allocated nonzeros=73874784
            KSP of A00
processes
                type: gmres
Gram-Schmidt Orthogonalization with no iterative refinement
divergence=10000
processes
                type: hypre
call 1
coarsening 0
coarsening 1
                  type: mpiaij
nodes, limit used is 5
            A01
                type: mpiaij
                rows=2793120, cols=931040
limit used is 5
          type: mpiaij
    type: mpiaij
    rows=3724160, cols=3724160, bs=4
    total: nonzeros=393998848, allocated nonzeros=393998848
What could be going wrong here ? Is it something related to null-space
setting ? But I do not know why it does not arise for smaller domain sizes!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131016/b95f3755/attachment-0001.html>
